Activity Forums Apple Motion Motion Layouts wont save
  • Motion Layouts wont save
    Posted by Dixon Johnston on June 30, 2009 at 7:32 pm
    My Window layouts wont save.
    Im working in Motion 2.
    I dont know exactly where they are supposed to be saved, so I cant backtrack it that way. Basically, I rearrange the windows every time I open a project.
    When I go to “save current layout”, I enter the name in the field, “enter” and it goes away. It never shows back up under the layout tab, where I always have the same 2 options “Standard” and “Alternate”-“Cinema” is grayed out. Ive trashed preferences, and reinstalled the from the Motion 2 crossgrade discs.
    Any advice is greatly appreciated.
    Thanks in advance, Dixon
    Dixon Johnston
    Creative services Director-WRIC
    Dual 2.0 G5, 4G RAM
    OSX 10.4.1, FCP 5.1, QT 7
    AJA Io-Beta SX (SDI)
    Dixon Johnston replied 17 years, 2 months ago 2 Members · 2 Replies
  • Ariane Fisher
    June 30, 2009 at 9:34 pm
    The UI layouts should be at:
    userLibraryApplication SupportFinal Cut StudioMotionUI Layouts
  • Dixon Johnston
    July 1, 2009 at 1:51 pm
    Thank you! Problem solved
    I couldn’t find the folder because it didn’t exist! Although I’ve reinstalled Motion 2 a few times, it never actually created the UI Layouts folder-weird! My solution, using your file path as a starting point was this:
    I copied the folder from another Edit suite which had 2 saved custom window layouts, and put it in the right place on my machine-now everything is saving.
    Dixon Johnston
    Dual 2.0 G5, 4G RAM
