Activity Forums Adobe Premiere Pro Motion Keyframe Troubles
  • Motion Keyframe Troubles
    Posted by Inkling on October 18, 2006 at 7:03 am
    I’m having trouble with motion keyframes in Premiere 1.5
    I’ve set 4 keyframes on a title to make it zip on-screen (from off-screen), move slowly across the frame (right to left), then zip off-screen. The title lasts about 7 seconds. The trouble is that in the middle of the r-l movement, the title will move slowly back to the right, then resume it’s correct movement after a second.
    They keyframes are all set to Linear, though I’ve tried other types with no luck. I get the same results with different titles and on two different computers with PP 1.5, so I imagine this is operator error. Hopefully I’m missing something obvious and someone here can put me on the right track.
    Thanks.
    Mike Cohen replied 19 years, 11 months ago 4 Members · 3 Replies
  • Mike Velte
    October 18, 2006 at 11:31 am
    Suspect two keyframes stacked almost together…try zooming in on the timeline view of the Effects Controls palette.
    Detail the position value and timecode of each keyframe so we can duplicate.
  • Steven L. gotz
    October 18, 2006 at 2:26 pm
    I remember this problem. It used to happen to me now and then. Delete all of the keyframes and start over. I believe that Premiere Pro “remembers” a keyframe that is no longer there.
    Steven
    https://www.stevengotz.com
  • Mike Cohen
    October 18, 2006 at 5:01 pm
    I found it is very easy to accidentally have a keyframe where you do not want it. And remember if you shorten a clip, it retains the keyframes beyond the in or out points, in which case deleting the keyframes is the answer as Steven suggested.
    Do not rely upon clicking a keyframe and adjusting its properties – always use the next/prev keyframe button. This gets unweildy if you have placed seemingly synchronous keyframes on multiple effects on the same clip – if keyframes are offset by even 1 frame, you can add a new keyframe without realizing it – especially if you are not zoomed in on the keyframes in the effects controls.
