Activity Forums Apple Motion Motion keeps crashing.Please HELP!
  • Motion keeps crashing.Please HELP!
    Posted by Alex Quintanar on December 5, 2005 at 5:48 am
    I’ve been running Motion 2.0.1 and it keeps crashing on me. I checked some of the previous threads and posts and I seem to be getting the same crash report, but the difference is that I don’t have a Blackmagic or AJA link. Motion is stable and doesn’t crash when I disconnect the CRT Phillips 20″ TV that I have hooked up to the second port on the ATI Radeon 9650 (DVI->S Video adapter). I’m using a dual 2.7 with 2.5 Gb of RAM. I’m still just learning how to use Motion with the tutorials so I don’t think I’m pushing the program that hard. Motion will launch and I can open up a project with the 2nd display on for monitoring but the second I toggle to another application like Safari or Itunes it goes down and gives me this crash report:
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
    Do I need more RAM or could it be the video card?
    Any suggestions. (BTW I cleaned up Font Book and that didn’t seem to help at all)
    Alex Quintanar
    “To be or not to be. What was the question?
    E. Eric johnson iii replied 20 years, 9 months ago 4 Members · 6 Replies
  • Noah Kadner
    December 5, 2005 at 6:35 pm
    Trash prefs and the like- and then try a reinstall and Software Update.
    Noah
  • E. Eric johnson iii
    December 11, 2005 at 4:46 am
    life is so uncertain…
    OK, i’ve done all of what was mentioned earlier in this thread, minus the second monitor deal and motion is still crashing. i do not have a decklink card so that’s not the deal, any ideas?
    e. eric johnson iii
    eric@lillcreates.com
    lill creates: founder/executive producer
    Water Channel: producer/virtual set operator+?
  • Jim Kanter
    December 12, 2005 at 3:32 am
    Did you have Motion 1 installed at any time?
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
    December 12, 2005 at 4:41 pm
    yes, and i blew it out prior to loading motion 2. this seems to have happened after the update. i hadn’t had any projects requiring motion for awhile, then #*^%#$@@!!!!
    so, i re-reinstalled motion 2 and it works better; however, it still crashes or is sluggish at best.
    e. eric johnson iii
  • Jim Kanter
    December 12, 2005 at 5:12 pm
    December 12, 2005 at 6:28 pm
    thank you jim… i’ll give ’em a try and post with the results. thank you for the time and input. glory to the cow!
    e. eric johnson iii
