Activity Forums Adobe After Effects motion jitter in HD vs SD
  • motion jitter in HD vs SD
    Posted by Alisa Placas on April 6, 2005 at 6:03 pm
    I have noticed an increased amount of motion jitter when working in HD.
    I’ve been setting up the image move comps and previewing them on an HD CRT monitor. It really seems to me that there is a great deal more motion jitter going on in a move than I typically come across in SD compositions.
    I have motion blur on for the images, am rendering to fields, and I’ve also overridden the shutter angle in the render settings. In some, I’ve gone up to a shutter angle of 720 degrees and am STILL getting a motion jitter (not moires, but a stuttering in the move).
    I don’t even know what else to do to try to get rid of this. Adding a fast blur might help, but it decreases the quality of these images too much. I’ve shorten the move or reduced the speed whenever possible, but that still isn’t enough in many cases.
    As I am unsure as to WHY or WHAT is making this difference in SD vs HD moves….I am unsure how to try to fix it.
    Have you come across any problem such as this in your work in HD?
    Alisa Placas
    Lucid Animation
    Cambridge, MA
    Alisa Placas replied 21 years, 5 months ago 3 Members · 4 Replies
  • Haze
    April 6, 2005 at 6:33 pm
    Never done HD in AE, but I’ve done a lot of editorial with 24p HD originated material (downconverted to SD). When the camera moves too quickly there’s a tremendous amount of jitter. This is related to the pulldown – the movement between frames is far enough that the offset of the fields produces jitter.
    Posting your comp settings would be helpful. Frame rate, progressive, interlaced, etc.
    I’m out of my element here.
    Cue: Steve
  • Alisa Placas
    April 6, 2005 at 7:43 pm
    The comps I’m working with are:
    1920x1080i
    29.97
    square pixels
    I’ve been rendering to the DVCPro HD codec….upper field first.
    motion blur is ON
    Alisa Placas
    Lucid Animation
    Cambridge, MA
  • Paul Carlin
    April 7, 2005 at 11:43 pm
    Create a small white solid and move it across the screen left to right for 30 frames. Render it out as Upper field first and Lower field first.
    This is the easiest, fastest and sure-fire way of knowing which dominance works.
  • Alisa Placas
    April 8, 2005 at 12:10 pm
    Thanks.
    Sounds like field order might be the issue.
    I didn’t even think of that because I’d read that HD was “upper field first”….but I am watching these with a Blackmagic card and their codec is “lower field first,” so, hopefully, that is the issue.
    Alisa Placas
    Lucid Animation
    Cambridge, MA
