Activity Forums Adobe Premiere Pro motion is pixelated after being burned to DVD
  • motion is pixelated after being burned to DVD
    Posted by Spiro on May 31, 2005 at 7:29 pm
    I can’t figure this out. Any motion I have in my sequence – like people running or text flying around (imported from AE) – turns out looking all pixelated after I burn the sequence onto a DVD.
    For my Encoding settings I’ve tried the Custom Presets, as well as the NTSC DV 4×3 Low Quality 3MB VBR 1 Pass setting. I would try one of the High Quality settings, but Premiere claims that there’s not enough DVD space for this.
    Any ideas?
    Mike Velte replied 21 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Mike Velte
    May 31, 2005 at 9:10 pm
    3MB VBR is not enough for video with motion. How long is your movie?
    https://www.video2stream.com
  • Spiro
    May 31, 2005 at 9:27 pm
    It’s slightly over 3 minutes long.
  • Mark Palmos
    May 31, 2005 at 10:56 pm
    hello spiro
    i have just burned a 2 hour wedding to a dvd which was encoded at about 5mb, so you should have PLENTY of space if your show is just 3 mins long!
    perhaps you have the timeline work area set to 3 hours or something?
    mark.
  • Spiro
    May 31, 2005 at 11:28 pm
    Mark – how did you go about setting the encoding to 5mb? I don’t see this as an option???
    Thanks for the help.
  • Mike Velte
    June 1, 2005 at 11:50 am
    7 mbps constant bitrate should work better than 5.
  • Mark Palmos
    June 1, 2005 at 12:00 pm
    spiro, i used 5mb because 7 would not fit a two hour show on a 4.7 gig disk.
    your show is very short, so 7 would be perfect.
    its there in the presets… do you not see it?
    mark.
  • Spiro
    June 1, 2005 at 3:51 pm
    No way. The High Quality 7mb CBR 1 Pass totally worked! I thought for sure I had tried that option after first installing PP 1.5, but it gave me a “not enough memory” error. Oh well.
    I’m curious – under the Encoding section, what does the “Fields” option do? Does it really matter what I have selected there?
    Thanks tons for the feedback! No more pixelated mess!
  • Mike Velte
    June 1, 2005 at 9:28 pm
    Fields is (are?) VERY important. Mucking with those settings can cause strobed motion on a TV. “Lower” is default and correct for video from a DV cam.
