Activity Forums Apple Final Cut Pro Legacy Motion Integraton – Replacing footage
  • Motion Integraton – Replacing footage
    Posted by Les Kaye on November 8, 2005 at 5:03 am
    How does one change out the footage in FCP on clips sent to Motion? I couldn’t find it in the manuals and it certainly doesn’t seem intuitive. I did try replacing it in the subclip created when the clips were sent to Motion, but that didn’t work either.
    -Les
    Martin Baker replied 20 years, 10 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    November 8, 2005 at 2:05 pm
    Change the clips in Motion… i.e. open the motion project, make changes, then it should be updated in FCP to reflect those changes.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Les Kaye
    November 8, 2005 at 2:17 pm
    [Jerry Hofmann] “Change the clips in Motion… i.e. open the motion project, make changes, then it should be updated in FCP”
    Thanks Jerry…but how do I EASILY replace the FCP footage in Motion? I work in multiclip with 6-10 cameras, with each take generally at least an hour. In this instance I need 20 frames of the take. The suggestion on the Motion forum was to render (export?) from FCP and replace the footage in Motion. Are we discussing the same solutions?
    -L
  • Martin Baker
    November 8, 2005 at 6:32 pm
    Easily is another matter…it won’t be fun. Would certainly be nice to have access to those source clips directly in FCP…
    Martin
    Digital Heaven, London UK
    ________________________________________
    NEW! VideoSpace – free diskspace calculator widget
  • Jerry Hofmann
    November 8, 2005 at 11:08 pm
    I’m a bit confused possibly, but If all you need is another 20 frames of something already in the motion project, why not just add the frames in Motion in the timeline window there? you can drag a clip longer there with ease anyway… or just import those 20 frames if they are not already part of another clip… as was suggested in the Motion forum.
    Jerry
  • Les Kaye
    November 9, 2005 at 2:43 am
    Thanks Jerry. No, it’s not a matter of simply trimming x number of frames, but actually replacing one of the FCP clips with a completely different one – apparently not an easy task from what I gather. On the one hand it’s a little surprising since the Motion team is basically the former Combustion team, where the integration with edit was/is almost sublime (In edit, the Combustion clip is placed ABOVE the edit footage sent over. Meaning that the actual Combustion clip can be copied and placed elsewhere on a timeline (or timelines), and thus could be re-rendered using the different footage below the duplicated/moved Combustion clip.
    I do have a sneaking suspicion that given the team’s heritage, this would be something that will show up eventually – if only because it’s too clunky now…
    -Les
  • Martin Baker
    November 9, 2005 at 9:18 am
    It’s interesting what you’re saying about the Combustion/*edit integration. Do you mean that the clip sources for the combustion project are “live” in the *edit timeline, so they can be changed at any time and the Combustion clip will automatically update?
    In FCP I’d really like to be able to “peek inside” the Motion clip and get a sub-timeline where you could replace the footage if you wanted to.
    Martin
    NEW! MovieLogger – QuickTime logging made simple
  • Les Kaye
    November 9, 2005 at 3:44 pm
    [Martin Baker] “Do you mean that the clip sources for the combustion project are “live” in the *edit timeline, so they can be changed at any time and the Combustion clip will automatically update”
    Yep. Just re-render.
    [Martin Baker] “In FCP I’d really like to be able to “peek inside” the Motion clip and get a sub-timeline where you could replace the footage if you wanted to.”
    Which is why I’m surprised it doesn’t do this now, since a nested clip is created in the bin. I tried changing this nested clip, but it didn’t work either.
    Thanks.
  • Martin Baker
    November 9, 2005 at 4:03 pm
    Wow that’s really cool. Make sure you go and log it as a feature request.
    Martin
