Activity Forums Adobe Premiere Pro motion installed, still missing prores codecs
  • motion installed, still missing prores codecs
    Posted by Scott Tupper on January 31, 2013 at 6:09 pm
    Everywhere I have looked the only way to get ProRes encode/decode on a Mac Premiere Pro system is to buy either FCPX, Motion or Compressor. I picked up Motion for $50, installed it.
    No ProRes in any Adobe app.
    What gives?
    Do I need to copy files into a QuickTime library?
    Did I just blow $50?
    Angelo Lorenzo replied 13 years, 7 months ago 3 Members · 3 Replies
  • Scott Tupper
    January 31, 2013 at 6:54 pm
    So I found a post over @ Adobe. forums.adobe.com/message/4447748
    Had to install the ProApps Codecs v1.0.1 and magically the codecs appeared.
    I hope this helps others.
  • Jeff Pulera
    January 31, 2013 at 9:16 pm
    I find it ironic that PC users don’t have to buy, or do, anything really for ProRes support, as long as the free QuickTime is installed. Just an observation
    Jeff
  • Angelo Lorenzo
    January 31, 2013 at 10:27 pm
    Well decoding is free on both systems with Quicktime installed.
    For encoding on Mac, you have to install an Apple Pro app which comes with the ProRes encoder. Final Cut, Motion, etc. Motion is usually the cheapest of the bunch so it’s popular to pick up.
    Windows users are stuck with commandline tools like FFMPEG and FFMBC to encode ProRes. It’s free, but I think Mac support for these tools are spotty. Regardless, the workflow is complicated. I created a helper program for batching ProRes, https://www.fallenempiredigital.com/blog/prhelpersoftware/ but there are also a few less niche GUIs that can help you encode single files.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
