Activity Forums Apple Final Cut Pro Legacy Motion in FCP
  • Posted by Gempic on February 23, 2007 at 1:15 am
    Jello,
    Is there a way to adjust the speed or motion of your footage in FCPHD without right clicking On the clip. I find when you adjust speed it’s very choppy. Is there a smother way? I’m doing variable speeds as well as reverse and forward.
    Is there a motion adjuster in FCPHD?
    Joseph Owens replied 19 years, 6 months ago 4 Members · 5 Replies
  • Andy Nitchman
    February 23, 2007 at 2:54 am
    Do answer your first question yes there is another way of changing the speed of a clip without right/control clicking it. One is Modify>Speed. the other faster way is cmd-j.
    To smooth out the motion try toggling the blend frames option. Also you might want to check out Graeme Nattress’s G Map Frames filter https://www.nattress.com/Products/standardsconversion/GMapFrames.htm
    Keep in mind you’ll never get a true slowmotion effect without shooting at a higher speed(>30/24). As for speeding stuff up you can get away with a lot more. If you have it, you may want to experiment with Apple’s stock stop motion filter.
    hope that helps
    -AnDy
    FCP 5
    2.0GHz Dual-core G5
    2 GB RAM
    NVIDIA GF 6600 256
  • Gempic
    February 23, 2007 at 3:21 am
    I meant a more inteligent, dificult way not short cuts.
  • Shane Ross
    February 23, 2007 at 3:24 am
  • Gempic
    February 23, 2007 at 4:08 am
    Thank you sir
  • Joseph Owens
    February 23, 2007 at 5:25 pm
    And if you want an even more difficult, time-consuming way to do slow-motion, try Shake’s “interpolation” mode. It generates new “original” frames using a mesh algorithm. It does also have a “blend” and “nearest” mode — but you can get that in FCP.
    JPO
