Activity › Forums › Apple Motion › Motion help
  • Motion help
    Posted by Robbie Salvuch on July 21, 2009 at 11:18 pm
    When I open up Motion, my file browser, library, and inspector will not show up on the left side of the screen. i can’t pull it up anywhere. Can someone pleas help. Thanks
    Zak Peric replied 17 years ago 5 Members · 6 Replies
  • Stephen Smith
    July 21, 2009 at 11:26 pm
    Go up to Window, you will have some options like file browser. Select it and that should get it back. Hope this helps.
    Lone Peak Productions
    Check out the TV Show Open I did.
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
  • Robbie Salvuch
    July 21, 2009 at 11:32 pm
    I have tried that and it still will not show up. I wasn’t sure if it was a setting or something
  • Stephen Smith
    July 21, 2009 at 11:39 pm
  • Jason Diebler
    July 22, 2009 at 3:20 pm
    Are you using Spaces? I lose windows occasionally too, especially when I Apple+Tab a lot, but it’s ’cause I have Spaces activated. I think the windows are gone, but they’re not, they just moved to one of the other desktop spaces… strange. So, I save my Window Layouts so I can reset… curious if anyone else has this happen to them w/ Spaces activated??
    “The deepest blues are black” – Foo Fighters
    (this doesn’t help me when I’m chroma keying!)
  • Bobby Good
    September 16, 2009 at 9:46 am
    Hey Robbie!
    did you get a fix for that problem?
    I now have the same issue.
    Best
    Bobby
    bobby
  • Zak Peric
    September 16, 2009 at 11:20 am
    Please delete the preferences of Apple Motion. This usually fixes the problem.
    Go to the following location: your home folder/library/preferences, then find the file called com.apple.motion.plist and delete it. (while you are doing this make sure that your motion is not running).
    Restart you Motion, you should be able to see all.
    If not you have to reinstall Apple Motion from original disk.
