Activity Forums Adobe After Effects Motion Graphics – Best Render Settings To 16/9 PAL in Final Cut Pro ?
  • Motion Graphics – Best Render Settings To 16/9 PAL in Final Cut Pro ?
    Posted by Laurent Falleo on May 30, 2011 at 6:37 pm
    Hey Everyone,
    I am currently working on a documentary, that I’ll edit in a Final Cut – 16/9 Pal Apple ProRes 422 Sequence.
    I’m gonna have to do some motion graphics in After Effects for this purpose (Typography animation, Layer Thirds, Pictures Animations …)
    What format should I work on in After Effects to get the best kick-a** results in my Pal Sequence ?
    Should I design everything in a HDTV 1920*1080 25p Sequence, and then throw everything via the Prores 422 Codec into my Pal Sequence and Render it all in Final Cut ?
    Or should I design everything in plain 16*9 PAL, 1024*756 ? Or 720*576 Anamorphic ?
    The problem is that my typos and graphics seem to look kinda ugly in PAL.
    Thanks for your help
    Roland R. kahlenberg replied 15 years, 3 months ago 3 Members · 2 Replies
  • Steve Renard
    May 30, 2011 at 9:04 pm
    I don’t work in PAL much, but in my experience the best quality I’ve gotten with NTSC when dealing with a 16×9 anamorphic project has been to scale the horizontal value and lock the vertical value. ie – for a 720×486 anamorphic timeline in FCP, I would use an 864×486 comp in AE. Trying to have Final Cut scale down a 1920×1080 into an anamorphic timeline will be a render hog and the quality will not be very good, IMHO.
    Cheers,
    Steve
  • Roland R. kahlenberg
    June 1, 2011 at 1:02 am
    What you render out of AE should be what your FCP sequence is expecting. If it’s SD anamorphic then render out in AE accordingly. Your workflow should ideally be in square PAR, non-anamorphic, until the final step prior to rendering. You then nest the square PAR into an anamorphic comp (AE will scale automagically to fit the comp).
    If your final output is SD then work in SD – 1050×576 (CS4 and newer) until the rendering step. Render out as ProRes.
    HTH
    RoRK
    AE Training in South East Asia. AE templates for sale and rental. Click here for more
