Activity Forums Adobe After Effects Motion Graphic Template: How to use different font styles in one MGT text line
  • Motion Graphic Template: How to use different font styles in one MGT text line
    Posted by Marlon Bos on August 18, 2020 at 3:27 pm
    Hi dear all, my brain is crunching, but I can’t think of a solution. Hopefully someone here can help me out.
    I’m designing title animations in AE, and export them as Motion Graphic Templates. If I import and use them in Premiere, I can change the actual text, but can’t change the style (bold or light) per word.
    I can ‘Enable Custom Font selection,’ but then the whole line of text changes. I want to be able to change just one or more words from for example a light to a bold style.
    I’m thinking of an AE expression on the text layer that finds and replace the style of words starting with for example the sign @. But I can’t get it done. Also tried Animators & Selector that search for words starting with @ and change the stroke width creating a faux bold style, which works, but then I’m not able to hide the @-sign..
    I can change the style with an expression, but only all the text, and not just a (couple of) words..
    Is there a way?
    I’ll keep trying though ☺ Will let you all know if I found something! Thx!
    Filip Vandueren replied 6 years, 1 month ago 3 Members · 2 Replies
  • John Cuevas
    August 18, 2020 at 4:05 pm
    I just created a mogrt for a company and ran into the same problem as you. The best solution I came up with is to create a separate precomp for every line of text. It was the only way that gave me the ability to have different fonts and font sizes. Fortunately for me, I was just creating a lower third-so I only needed 3 precomps.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Filip Vandueren
    August 18, 2020 at 6:20 pm
    Here’s my solution for HTML-parsing a text, as previously posted on the cow.
    https://we.tl/t-uWFHgVPymS (now updated for Javascript engine)
    If you write a text like:
    hello crazy world.
    The expression will apply the text-animator named “b” to everything between and
    You can create as many different tags and text-animators as you need.
