Activity Forums Adobe After Effects Motion graphic (?)
  • Motion graphic (?)
    Posted by Gigi Marzo on January 30, 2014 at 9:42 am
    Hi, I would produce a videoclip like this https://vimeo.com/31928186
    Now I have any questions:
    1) For example across the minute 1:41 to 1:43 and 1:50 to 1:54 how I do the animation like this on a person?
    2) The other animations is better to make with software like AI or can I use directly AE?
    3) If you want give me a tip, please.
    Im sorry for my little english, thank u in advance.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Stephen Smith replied 12 years, 7 months ago 3 Members · 2 Replies
  • Jason Jantzen
    January 31, 2014 at 3:17 pm
    That’s a pretty basic drawing over the top of your video technique. It’s a frame by frame animation, so technically you could take it into Photoshop and then draw on the frames there. In fact, that’s how I’d do it I’d I had to. I’d also reduce the frame rate before drawing on it, which you can do on import into Photoshop. Just make sure you export the section of video frames you need so that you know what the start frame is. It’s also easier to work on chunks of video in Photoshop instead of the whole clip.
    Jason Jantzen
    vimeo.com/jasonj
  • Stephen Smith
    January 31, 2014 at 10:02 pm
    Take a look at this: https://vfxbro.com/lightstreak/
    Stephen Smith
    Utah Video Productions
    Check out my Vimeo page
