Activity › Forums › Apple Final Cut Pro Legacy › motion fx probelm
  • motion fx probelm
    Posted by Niti Shah on December 19, 2005 at 11:02 am
    hi
    I am facing a major problem with motion fx . My clip’s motion properties get changed badly. I repaired my timeline, repunch clips on timeline, kept motion to 50%. After three four days it was messed up again. It happened twice or thrice. Can
    David Bogie replied 20 years, 9 months ago 2 Members · 1 Reply
  • David Bogie
    December 20, 2005 at 4:08 pm
    I don’t think we have any idea.
    There is obviously a translation problem here, you are describing an issue in terms that do not easily relate to FCP. I would hesitate to make any suggestions based on that same translation problem.
    I will try anyway.
    I believe the renders are being replaced in the background. Turn off background rendering. Make sure your render settings match exactly your sequence settings and your sequence settings match exactly your clip settings.
    bogiesan
