Activity Forums Adobe Premiere Pro Motion file format ??? PMF? PMT?
  • Motion file format ??? PMF? PMT?
    Posted by Mr_red on February 12, 2007 at 4:32 pm
    Hi
    Premiere 6.5, clip attributes/set-up
    I wanted to produce a file that would define the motion of a clip – in this case stills. Efectively create my own transitions.
    Having looked at the motion (etc) file some entries are obvious like “zoom=” others need a clue like “fraction” entries.
    Most parameters “save as” integers. I was wondering if I can use at least one decimal point to improve (say) circular motion. The specific data would come from a spreadsheet.
    So – is there an explanantion of the file format of this file and others (if they are amenable to inspection with simple apps like notepad)? And where is it?
    TIA
    Mr_red replied 19 years, 7 months ago 1 Member · 1 Reply
  • Mr_red
    February 13, 2007 at 12:59 pm
    So far so good.
    Spreadsheet macro can generate the position (etc) values in a usable file.
    However the mathematical values make the motion lumpy because Premiere reads only the integer part of any entry/line/field. But is not phased by decimals.
    There are lines referring to FracV & FracH & Fracspot so it looks possible. The experiment continues. I will report back here when I have more info.
    spot= the posn of the centre
    zoom= in %
    time= scaled to 1000 = 100%
    rot= rotation in degrees
    dest= seems to be skew, and entry containing 0’s 80’s and 60’s is probably without any skew.
