Activity › Forums › Apple Motion › Motion export movie: drop zone still visible
  • Motion export movie: drop zone still visible
    Posted by Kevin Kuipers on March 1, 2014 at 7:10 am
    Hello all, I have created a Title project in Motion. I would like to export it to a “transparant” movie so it can be used by somebody else as an overlay video (they are not using FCPX)
    Problem is that whatever I try, I keep having the Dropzones visible.
    I tried the pro res 4444 codec, but that is not the solution (so far).
    Thanx for any advice,
    Kevin Kuipers
    Mark Spencer replied 12 years, 7 months ago 2 Members · 5 Replies
  • Mark Spencer
    March 1, 2014 at 3:12 pm
    Turn off the drop zone.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Kevin Kuipers
    March 1, 2014 at 3:28 pm
    Hi Mark, thank you for your fast reply 🙂
    If you say turn of the drop zone, do you mean deleting them? Since if I do that, the project is changed in such a way, that the output is different. Or is there a “alternative” way to turn them off? I so could you explain shortly how?
    Kind regards,
    Kevin
  • Mark Spencer
    March 1, 2014 at 3:31 pm
    I mean click the activation checkbox for the dropzone layer to make it inactive, i.e., invisible.
    Mark Spencer
  • Kevin Kuipers
    March 2, 2014 at 7:27 am
    If I uncheck the drop zone , than I see the other layer, in this case the white background. If i export this movie, nothing is transparant anymore, and than I miss my “transparant” boxes at the right.
    See screenshots included.
    What I’m looking for is that the boxes at the right are “transparent” in the exported video file, and not showing the “arrow drop zones”
    To illustrate I have also included the motion file. If it would be possible for you to have a quick look at my project you can find it in the link below.
    7178_soldintro.moti.zip
  • Mark Spencer
    March 2, 2014 at 3:28 pm
    Kevin, there is no transparency in that template. There are dropzones, there are colored shapes. If you want the dropzones themselves to be transparent, that would take a lot of work to re-engineer the project.
    Mark Spencer
