Activity Forums Adobe After Effects Motion Effect
  • Motion Effect
    Posted by Hans Meier on January 5, 2008 at 10:59 am
    Hey everyone,
    I’m sure that this effect had been discussed a couple of times, but I just don’t know how it might be called so I couldn’t find anything.
    Take a look at this:
    https://www.zippyvideos.com/5013602097387976/lost2/
    It looks like the video is playing at 200% but it isn’t, right? I guess it’s more like that every second frame is deleted – but how can you achieve this with AE?
    Any help would be appreciated.
    Mike Clasby replied 18 years, 8 months ago 3 Members · 2 Replies
  • Joe Moya
    January 5, 2008 at 5:52 pm
    This looks like simple cut editing (i.e., no transitions) done effectively with the appropriate camera work.
    I don’t see any strobing… or, if there is any strobing it is very sparsely used… however, I do see numerous foreground objects that are moving at faster rate than the main background…. which you may be confusing with a “faster” film rate look.
    I see nothing in this video that was done with AE… any pro level NLE can do this kind of editing very easily. I guess you could use AE… but, it would be more difficult and you would be using a less efficient editing tool.
    Joe
  • Mike Clasby
    January 6, 2008 at 7:42 am
    I think there is a little choppy something going on when you see the bald guy.
    This Dan Ebberts expression on Time Remapping, drops every other frame:
    n = 2;
    n*time
    Or…
    For a choppy look running at the same speed, then add the effect Time>Posterize Time and set it to half the comp frame rate.
