Activity Forums Apple Final Cut Pro Legacy motion clip failing to render
  • motion clip failing to render
    Posted by Anthony Faulkner on May 28, 2010 at 12:06 pm
    I am pulling my hair out. This isn’t the first time this has happened.
    I complete a motion3 clip That is three group clip
    emitter at the rear, text in the middle and another emitter at the front.
    I Copy it into FCP6.0. It looks fine in the viewer. I put it in the timeline, it looks fine unrendered. I render it and half way through the front emitter group just disappears. it rolls back like a moving crop.
    I try changing the original motion clip and resaving it, reloading it. exactly the same thing happens.
    I am not sure what to do here…
    Any suggestions??
    Jerry Hofmann replied 16 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    May 28, 2010 at 12:19 pm
    Export the clip as a QuickTime movie from Motion and import that file into FCP to cut into the sequence.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
