Activity › Forums › Maxon Cinema 4D › Motion camera
Motion camera
Posted by James Yau on October 7, 2011 at 6:24 pmHow do i get a camera follow an object around ?
Adam Trachtenberg replied 14 years, 10 months ago 2 Members · 3 Replies -
Adam Trachtenberg
October 7, 2011 at 10:53 pmYou mean you want the camera’s position to follow the object’s position, or you just want the camera to point at the object?
James Yau
October 9, 2011 at 11:25 amI want the camera to follow an object ( the objects position). For example think of some red blood cells floating down a vain or some kind of tube, i create an emitter and want the camera to follow one of the objects from the emitter though out the tube.
Adam Trachtenberg
October 10, 2011 at 1:50 pmIn that case it depends a bit on how the object is animated. For example, if it’s just a regular object KF’d by hand you could simply make the camera a child of the object, or use the Timeline’s motion path to spline function, and then align the camera to the spline. Or you could use a PSR constraint (characher>constraint tag).
Particles or mograph objects are a bit more complicated as you have to ascertain the index of the particle you want to use and then obtain the position data. What I would do is clone onto the particles and then use the mograph data node to get that info. You could then have a null follow the particle and have the camera follow the null (or offset it and make it a child of the null).
