Activity Forums Maxon Cinema 4D motion blurring
  • motion blurring
    Posted by Chris on June 17, 2005 at 9:55 am
    As motion blurring is so heavy on render times 9in C4Ddoes anyone know a good way of adding it in AE?
    I thought exporting the camera movement from C4D might work – but of course the image stays in track with the camera and so there is no movement for the MB to add to. Frame blending isn’t the answer as it just adds past frames and creates stuttered ghosting. What I really need is a smooth blur – or something that creates new ‘in-between’ frames through interpolating the standard frames. Anyone any suggestions?
    E
    Adam Trachtenberg replied 21 years, 2 months ago 3 Members · 2 Replies
  • Nicholas Toth
    June 17, 2005 at 8:54 pm
    cc force motion blur is a hog at rendering, but it is still quicker than c4d
  • Adam Trachtenberg
    June 18, 2005 at 5:51 pm
    Reelsmart Motion Blur is an excellent AE plugin–particularly if you use it with Core Arsenal’s Vixol plugin (for Cinema) to provide vector info.
    But with regard to Cinema, have you tried using vector motion blur instead of scene motion blur? The results are so-so, but it’s hella faster.
