Activity › Forums › Maxon Cinema 4D › Motion blur with thinking particles?
  • Adam Trachtenberg
    December 8, 2008 at 10:31 pm
    Works fine here. Which kind of motion blur are you using (scene, vector, object)?
  • Brett Waszkelwicz
    December 8, 2008 at 10:40 pm
    Anything but SMB. I know that will prob work, but there are some other elements that are moving slowly that will still probably blur (that I don’t want to) if I use SMB. If either of the other two are working for you, which objects are you putting the tags on?
    thanks
  • Adam Trachtenberg
    December 9, 2008 at 2:53 am
    I tried vector motion blur but not object (which I avoid like the plague). Put the tag on the particle geometry object.
  • Brett Waszkelwicz
    December 10, 2008 at 5:01 pm
    Thanks! don’t know how I missed that.
