Activity Forums Adobe After Effects motion blur query
  • motion blur query
    Posted by Chris Brett on September 6, 2013 at 10:19 am
    Hi
    — when I use motion blur there is no ramping of the effect – ie the blur does not fade gradually away and appears rather like a soft transparent block following the object.
    Anyone got any ideas on how to make this taper away nicely please ?
    Chris Brett
    Chris Brett replied 12 years, 12 months ago 2 Members · 3 Replies
  • Chris Brett
    September 6, 2013 at 4:05 pm
    Hi Dave – thanks for the speedy reply …
    …………….. get motion blur ok which is proportional to speed but its all the same weight — ie the pixels ( in the blur ) furthest from the object are the same density as those nearest ( I think ) …..
    …………. perhaps I need to take a closer look at it — in the meantime please what is you favourite setting for motion blur and Ill start with that …
    All the best
    Chris Brett
  • Cassius Marques
    September 6, 2013 at 6:06 pm
    go to your composition settings and check for how much samples are set for motion blur in the advanced tab… default is 16 and 128.
  • Chris Brett
    September 7, 2013 at 12:04 pm
    thanks Cassius –much appreciated –
    – I reckon this is probably the answer though cant see how I managed to miss it !
    …….. all the best
    Chris
