Activity Forums Adobe After Effects Motion Blur Overlap
  • Motion Blur Overlap
    Posted by Tyler Yowell on April 4, 2007 at 7:33 pm
    I am using precomped images with a camera sort of panning (paning?) over them in 3d space. As I move the different layers into the composition, I pan over them in succession. The problem is that sometimes one of the images on the bottom of the other 2 or 3 layers will occasionally (for just a half-second, then it goes back where it’s supposed to be) come back in over the layers on the top. I still want them to be visible on the bottom, even though just a corner is able to be seen.
    I turned off motion blur and the problem was gone, but I need motion blur in the comp.
    Don’t know if I explained that well enough. Thanks for your help.
    Kevin Camp replied 19 years, 5 months ago 2 Members · 1 Reply
  • Kevin Camp
    April 4, 2007 at 8:17 pm
    sometimes placing empty adjustment layers in between your 3d layers help ae figure out which layers are in front of other layers in 3d space.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
