Activity › Forums › Avid Media Composer › Motion Blur in Avid Xpress pro?
Posted by Mohamed Bilal on November 21, 2007 at 6:48 amBro…how we can make a motion blur effect in Xpress pro?i want to add motion blur effect for a moving object shooted in a study frame.And also want to know what are the 3rd party plugins and which is Best?Help me friends….
Pierre Jasmin replied 18 years, 8 months ago 4 Members · 5 Replies -
Grinner Hester
November 21, 2007 at 7:01 pmyou’ll get a lot of bang for the buck with Genarts Sapphire plug ins.
For the motin blur, you are best off doing that in after effects. It’ll give ya exactly what you are looking for in this case.
Mohamed Bilal
November 24, 2007 at 2:27 pmThanks Buddy….I cant work with AE much…so i have to work with AVID…
Grinner Hester
November 24, 2007 at 3:05 pmgenarts sapphire has a blur called motion blur but its like a vator blur you’d use in AE or PS. Like, it uses a point then blurs from there. Useful in some cases but not as a motion blur.
You may be able to stack that clip. put a defocus on it using the direction your object is going (you will onty be able to blur it horizontally or vertically) and then use a nested mask to follow it. Again, not a truew motion blur but it’ll soften it pretty good.
Gary Oberbrunner
November 26, 2007 at 2:29 pmSapphire also has Blur Motion Curves; set its Mode to Blur Only, then just add keyframes and drag the Transform widget to follow your object and it’ll automatically add the proper motion blur. This works if the object translates (shift), rotates and/or zooms. Just make sure to set keyframes so the transform widget moves along with the object.
Of course you have to do this on a keyed foreground or the background will get motion blurred too. That can get a little complex on an Avid but it can certainly be done. Let me know if you’re interested in more details.
— Gary
Pierre Jasmin
January 14, 2008 at 4:19 amFYI
You can try the demo of RSMB for Avid here:
https://revisionfx.com/products/rsmb/downloads/#Avid%20SystemsPierre
