Activity Forums Adobe After Effects Motion Blur for Cut Out Object
  • Motion Blur for Cut Out Object
    Posted by Eric Goldstein on May 30, 2007 at 2:29 pm
    I have a still image of a cell phone that I cut out from its background. I’m moving it across
    another image as if it’s been thrown. I want to blur it to make it look more realistic, but motion blur is restricted because of the image is cut out and looks like a series of the object repeated rather than a blur.
    Does anyone have any suggestions on how to get a better looking blur in this circumstance?
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Eric Goldstein replied 19 years, 3 months ago 3 Members · 3 Replies
  • Kevin Camp
    May 30, 2007 at 2:40 pm
    you might try a little directional blur. adjust the direction to follow your motion. it shouldn’t take much blur to smooth things out.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Darby Edelen
    May 30, 2007 at 5:01 pm
    Two things I’d like to note:
    1. As I understand it, AE CS3 will let you choose the frequency of samples for Motion Blur. I haven’t played with this yet, but my guess is that it will increase render time but give much better results in the motion blur department. There was a post about this not too long ago, although I may have misunderstood it and Adobe may have just refined the motion blur method to give much better results… Something to look into!
    2. Linear blending (and optionally 32-bpc) can help give you more realistic motion blur, also at the cost of render time. If you’re not familiar with linear compositing then you might want to read up before you try this, it usually doesn’t work too well in 8-bpc.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Eric Goldstein
    May 30, 2007 at 6:20 pm
    Thank you all for your responses. I didn’t have time to look into the linear compositing, but I’ve put in on my list. In the end, combining directional blur with AE’s motion blur did the trick.
    Thanks again, for the help.
    Eric
    Eric Goldstein
    Los Angeles
