Activity › Forums › Adobe Illustrator › Motion blur effect?
Motion blur effect?
Posted by Darren Ruddock on November 1, 2010 at 9:48 pmDoes anybody know how this effect could be achieved on text?
The appearance of movement or even motion trails??
Lance Clayton replied 13 years, 4 months ago 3 Members · 2 Replies -
Vincent Rosati
November 3, 2010 at 7:53 pmHere’s one way…
Using Object/Blend, setting the tail object to Opacity zero.
Possibly adding Blend/Replace Spine and Outer Glow.Here’s an example file…
Adobe Illustrator Motion BlurVince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Lance Clayton
May 3, 2013 at 5:54 amAlso try the Blur>Radial Blur effect.
Set it to zoom and set the zoom centre to the appropriate position so as to imitate the direction that the object is supposed to be moving.
Probably wont work as pulling off the above, but it’s pretty universal and its quick and easy
