Activity Forums Adobe After Effects Motion blur colour outline
  • Motion blur colour outline
    Posted by Henry Gaunt on August 27, 2013 at 7:42 am
    Evening all,
    Due to the colours used (mandatory) I am getting a coloured outline on any motion blur in my project. You can see it here with the ‘6’ compared to the ‘1’ in the image below.
    Is there a way, if any, of fixing this – or most likely in AE – using a trick to get around the issue?
    Thank you,
    Henry
    Henry Gaunt replied 13 years ago 3 Members · 3 Replies
  • Cassius Marques
    August 27, 2013 at 2:39 pm
    I seems right as it should to me. A magenta blurring over a cyan background should display as blueish.
    You’ll have to think that you should see things playing at the desired FPS, not frame by frame. Your eyes should perceive things the way they are suppose to.
    If you want to avoid or reduce that, you’ll have to color correct with adjustments on top of that.
  • Walter Soyka
    August 27, 2013 at 3:40 pm
    Open your project settings (File > Project Settings, or Ctrl+Shift+Alt+K on a PC, Cmd+Shift+Opt+K on a Mac) and tick the box for “Blend Colors Using 1.0 Gamma.”
    This will change the math for blending colors and eliminate the dark fringing you’re seeing on the motion blur.
    Walter Soyka
  • Henry Gaunt
    August 28, 2013 at 2:47 am
    Thank you Walter. That’s exactly what I was after.
