Activity Forums Adobe After Effects Motion Blur Bug
  • Motion Blur Bug
    Posted by Michael Dodge on October 30, 2019 at 4:06 pm
    I am having an issue that I’ve had several times before with Motion Blur blurring frames after a movement has completed.
    (No position keyframes at this time on the timeline)
    Stranger still is that there is not motion blur on this asset throughout the comp flowchart.
    (Base level: Asset comp)
    (Comp containing asset with motion blur)
    (Comp where motion blur becomes an issue)
    I made sure to check through all layers of these comps to be sure that there is no misc. keyframes that could be messing this up.
    This issue has happened on previous videos and the problem rectified itself.
    Please let me know if you need further info.
    Oleg Pirogov replied 6 years, 10 months ago 3 Members · 2 Replies
  • Tomas Bumbulevičius
    November 2, 2019 at 9:06 am
    Hey Michael, any chance some motion blur applied in the pre-comps?
    See how continuous rasterisation ‘unchecking’ would change the situation. If it does, then most likely there is something inside vans pre-comp (effect/toggle), which causes an issue here.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Oleg Pirogov
    November 2, 2019 at 4:13 pm
    It’s a well-known issue with Motion Blur, though I don’t know an explanation for it. It has something to do with collapsed transformations and rendering order, so Tomas’s suggestion might work. Cleaning cash also helps usually.
    I would really appreciate a project file where this bug is present.
