Activity › Forums › Adobe After Effects › motion blur and ‘save’ query
  • motion blur and ‘save’ query
    Posted by Chris Brett on December 4, 2012 at 12:32 pm
    Hi there
    ——— motion blur is not working on any layers so I guess it is turned off somewhere…..
    I have it checked on for layers and the comp — anyone got any ideas please ??
    Also please, anyone know if when a file is ‘saved ‘ it also updates the ‘collect files’ associated with that file.
    ——— Chris Brett / / U K ——
    Chris Brett replied 13 years, 9 months ago 3 Members · 3 Replies
  • Levi George
    December 4, 2012 at 1:24 pm
    Hi Chris
    I’m sort of new to coding in After Effects myself so you’ll have to forgive and answer that will probably turn out to be no help at all.
    If Motion blur is turned on at both the layer and composition;
    It might be that Motion Blur on your composition is not be set high enough? You could right click on the Comp you are in check it’s Composition Settings and under the ‘Advanced’ tab check that it’s motion blur settings are high enough.
    If they are:
    Are you able to use a CC Force Motion Blur as an alternative?
    Or (and I hate saying this) have you tried restarting AF or your CPU?
    As for file collect. I don’t believe that saving updates the collected files. As far as I know you have to do a second file collect to update it.
    Hope I was some help.
    – Levi
  • Vishesh Arora
    December 4, 2012 at 1:40 pm
    chris
    Levi is right.
    Increase the Shutter Angle value to a higher number. By default it is 180 degree.
    See this article:
    https://provideocoalition.com/index.php/mchristiansen/story/tip_create_cinematic_motion_blur_in_after_effects_and_in_life/
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Chris Brett
    December 5, 2012 at 12:26 pm
    …… thanks Guys – much appreciated —–
    — turned out to be a combination of shutter angle — not 180 degrees but ‘low’ – and being in draft 3D ( I think ! ) …..
    — anyway — all sorted and many thanks………
    —————— all the best ——chris–
