Activity Forums Adobe After Effects Motion Blur and Layer Styles
  • Walter Soyka
    June 24, 2022 at 5:49 pm
    Layer styles are applied last in Ae’s render order (after masks, effects, and transformations, when native motion blur is rendered), so you won’t get the result you’re looking for from a layer style without precomping.
    If you can’t use the native text stroke, you could avoid precomping by rolling your own Stroke effect, because effects are rendered before transforms. Stack up these built-in effects:
    1. Minimax (to expand the layer’s boundaries, set to ‘Maximum’ and ‘Alpha and Color’)
    2. Fill (to fill in the entire text area, set the color you want the stroke to be)
    3. CC Composite (set to ‘In front,’ to comp the original layer source back on top of the expanded and filled text)
  • Malcolm Desoto
    June 24, 2022 at 6:08 pm
    Thanks, Walter. I guess precomps is still the easiest way to do this even though it’s an inefficient work flow.
  • Walter Soyka
    June 24, 2022 at 6:13 pm
    You can roll this into to effects preset, or copy and paste it. It takes a moment to set up the first time, but I think it’ll be much faster to maintain than bouncing around among precomps…
