Activity › Forums › Adobe After Effects › Motion Blur
Motion Blur
Posted by Anton Shu on August 21, 2012 at 9:38 amHello community. Is there a way to turn off motion blur for all comps/precomps/layers etc (for faster preview purposes) with a “single click”?
AntonAnton Shu replied 14 years, 1 month ago 2 Members · 4 Replies -
Tudor “ted” jelescu
August 21, 2012 at 10:24 amYes- you can turn it off using the switch at the top of the layers in the Timeline panel. Check the following link for more info:
Tudor “Ted” Jelescu
Senior VFX Artist -
Anton Shu
August 21, 2012 at 10:49 amMaybe I was not clear. I have lots of precomps, so that switch does not work, I have to go mannualy in every comp and turn that motion blur swith off. I have 3 steps of compositions..
Tudor “ted” jelescu
August 21, 2012 at 12:21 pmAs long as you turn that off in your main comp, it should be turned off for all precomps inside it. The same if you turn it on.
Tudor “Ted” Jelescu
Senior VFX Artist -
Anton Shu
August 21, 2012 at 12:42 pmYou are right. And I want to fill this gap..
scenario: main comp motion blur is off. precomped comp motion blur is on. in main comp there is still motion blur visible, but clicking on that switch to turn on, and again click to turn off, there you go..motion blur is off of all comps.
