Activity › Forums › Apple Final Cut Pro › Motion Blur
Motion Blur
Posted by Jason Jenkins on September 26, 2011 at 2:54 pmThe closest thing I can find to a motion blur in FCPX is ‘directional’ blur, which isn’t that great. Any way to create a motion blur effect in Motion 5 and publish to FCPX? Sigh. I may actually have to animate something in After Effects ;p
Jason Jenkins
Flowmotion Media
Video production… with style!Kripá Pizzorno replied 10 years, 8 months ago 7 Members · 12 Replies -
Andy Neil
September 26, 2011 at 5:16 pmWhat specifically are you trying to do? Motion 5 has motion blur, but it’s not a filter, it’s part of the interface.
Andy
https://www.timesavertutorials.com
Jason Jenkins
September 26, 2011 at 6:50 pm[Andy Neil] “What specifically are you trying to do?”
I’m animating a hockey stick that come swinging through the scene. I tried an export from AE with motion blur and I couldn’t tell what is was (too blurry!) so I’m sticking with the original animation in FCPX.
Jason Jenkins
Flowmotion Media
Video production… with style! -
Jason Jenkins
September 26, 2011 at 6:51 pm[Simon Ubsdell] “Here’s the “Motion Blur” filter published from Motion 5″
Thanks, Simon! I’m done with the current project, but I’ll test this out on the next one.
Jason Jenkins
Flowmotion Media
Andy Neil
September 26, 2011 at 6:57 pmIf you’re animating it in Motion, you can apply motion blur to it in the project settings. The higher the samples, the higher the quality (at the expense of more render time). The highter the shutter angle, the more blur. The default shutter angle of 360 is usually way too high. I start with about 90 angle, and 16 samples and adjust from there.
BTW, these settings apply to motion blur in AE which can be accessed through the comp settings.
Andy
Sascha Engel
February 20, 2014 at 3:54 pm -
Simon Ubsdell
February 20, 2014 at 5:42 pmI removed this because Apple’s Motion 5 version of Motion Blur isn’t Motion Blur at all, but just Directional Blur with a rotational control.
Here’s a sort of motion blur that’s OK-ish, which is basically the Motion 5 Wide Time filter republished:
https://tokyo-uk.com/fcpxeffects/Quasi_Motion_Blur_WideTime.zip
Might be useful in some instances – better than directional blur anyway.
Click the download link, unzip the archive and put the resulting entire folder in your User/Movies/Motion Templates/Effects folder.
Simon Ubsdell
http://www.tokyo-uk.com -
Rob Marty
January 13, 2016 at 5:56 pmI realize Im now replying to this in 2016.
Im not able to find any settings in Motion for motion blur. Im running the latest version of Motion 5.2.2
Did Apple disable this function? -
Simon Ubsdell
January 13, 2016 at 7:10 pm[Rob Marty] “Im not able to find any settings in Motion for motion blur. Im running the latest version of Motion 5.2.2”
Go to your Project Pane (Cmd+J) and you can find the motion blur settings there where they have always been.
Simon Ubsdell
tokyo-uk.com -
Brett Sherman
January 14, 2016 at 12:12 amAm I right that this only works with rendered Motion projects and not with FCP X templates? I’ve never been able to get motion blur in an FCP X template to work.
Andy Neil
January 14, 2016 at 12:49 amUnless they’ve made changes in the recent iterations of FCPX, then you are correct. Motion blur doesn’t carry over to FCPX from Motion.
In those cases, I export QT movies w/alphas and composite in FCPX.
Andy
https://plus.google.com/u/0/107277729326633563425/videos
