  • Posted by Roberto Beltran almanza on January 26, 2008 at 2:37 am
    hello… hope somebody help me…
    my doubt or problem its when i work with pictures in format jpg. and i add some motion on it… is use the icon called motion keyframe to give the move… and the problem its when i play it on tv… it seems to be pixelated… and kind of little jumps on ti… so, it doesn’t look with high quality… i wanna know my problem… maybe i need to enable some option in render or something…
    Tim Vaughan replied 18 years, 8 months ago 2 Members · 1 Reply
  • Tim Vaughan
    January 26, 2008 at 12:17 pm
    There is a setting in the preferences for render control, and for some odd reason, it is defaulted to good quality. Make sure it is set to best. Also check your sequence settings to verify that it is checked there as well. I did notice quite recently when I animated a few photos in FCP (using QT7.4) I got a LOT of jump during transitions. A trick I learned a while ago was to delete the projects render files and re-render from scratch. This has, in the past, done the trick. But this time around, though I can’t say for sure, I think QT 7.4 screwed that option. I ended up rendering the photo’s out in After Effects to get the smoothness required.
    Hope this helps
    Tim
    Tim
