Activity › Forums › Apple Motion › Motion 5 vs 4
  • Motion 5 vs 4
    Posted by Brian Cooney on October 6, 2012 at 2:36 pm
    I’m using Motion 4 and FCP and AE and in the process of making the switch to Premiere Pro and potentially Creative Suite exclusively. I’m just finding that Motion, compressor and FCP7 are starting to slowly breakdown … after recent OS updates and new pluggins on the market it seems Studio 3 is starting to die a slow death… any way… I use Motion 4 and compressor quite a bit and my question is… is the operation and functionality of Motion 5 and the new compressor similar to that of Motion 4 and Compressor 3? Or is it more like a new learning curve – like FCP7.0 to FCPX? Has anyone enjoyed the switch? I don’t think at this point I can, for professional needs, move toward FCPX , but I’m wonderign about the rest of the suite.. thanks.
    MotionFoundry, Inc. Video Post
    Clients: GM, AOL, Kohl’s, 3 Doors Down, IKEA, Kelloggs, Toyota, Thomas Nelson, NASCAR Affiliates
    Simon Ubsdell replied 13 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Mark Spencer
    October 6, 2012 at 2:56 pm
    Motion 5 works almost exactly the same as Motion 4 – except that the UI is darker, it’s fully 64-bit (completely rewritten), and has powerful rigging and publishing features for making effects for FCP X (which you probably won’t use). On the downside, the UI isn’t as configurable and you can only have one project open at a time. Compressor is basically the same.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Brian Cooney
    October 6, 2012 at 3:14 pm
    Thanks. That’s good to know. So I can pretty much begin using Motion5 out of the box as well as compressor? Do you know of any ocnflicts wiht havign earlier versions installed? wonder if I should do a clean installation of just FCP7.0.. I wouldn’t have the integration.. But I pretty much export form motion to FCP anyway. I don’t really like working wiht Motion within an FCP timeline… thanks so much. unless there’s aything else I need to know I may make the purchase. 🙂
  • Mark Spencer
    October 6, 2012 at 3:21 pm
    You can’t roundtrip between FCP 7 and Motion 5. You’ll need to export rendered movies from M5 instead. If you have both M4 and M5 it shouldn’t be a problem, but I would rename M5 so that if you *do* try to roundtrip from FCP 7, M5 won’t launch.
    Mark Spencer
  • Brian Cooney
  • Anders Larsen
    October 8, 2012 at 10:37 am
    “Send to Compressor” never really worked for me before Motion 5.
    In my experience as soon as you had a little bit of complexity in you motion project, something would go wrong when sending to Compressor without exporting first.
    That has all changed with Motion 5. Now I can send my project to Compressor, and then keep working in Motion while it renders. Well worth the $50 if you ask me.
  • Alex Udell
    October 12, 2012 at 4:50 pm
    Hi Mark…
    One feature I love about Motion are the abilities to:
    a) Copy and paste from one project to another
    b) Via the Browser, Drag Projects into other projects
    Can you still copy and paste if you can only have one project open at a time?
    does drag and drop still work?
    Thanks…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Simon Ubsdell
    October 14, 2012 at 7:31 pm
    [Alex Udell] “a) Copy and paste from one project to another
    b) Via the Browser, Drag Projects into other projects”
    Yes, both of these are still possible with Motion 5 and work just fine.
    However, as you know you can’t have more than one project open in this version which can be an annoying limitation at times, though not unworkably so.
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Alex Udell
    October 15, 2012 at 1:48 pm
    Hey Simon…
    So how does copy and paste work?
    Open Project, Select, Copy, Close Project
    Open Destination Project, Paste?
    Thanks…
    Alex Udell
  • Simon Ubsdell
    October 15, 2012 at 1:53 pm
    [Alex Udell] “So how does copy and paste work?
    Open Destination Project, Paste?”
    Yes, I’m afraid so – it can be pretty tiresome if it’s something you need to do a lot of. Maybe easier just to import a whole project and unpick it.
    Hope Apple fix this at some point.
    Simon Ubsdell
