Activity Forums Apple Motion Motion 5 rigging problem
  • Motion 5 rigging problem
    Posted by Dirk De jong on May 30, 2012 at 4:33 pm
    I find that if I include a parameter (in my case it’s an FxPlug filter parameter) in a rig, but then I delete that rig and save my project, the parameter still shows the joystick icon and seems to think it is attached to a rig. The option of adding that parameter to a rig is now gone, and I don’t know any way of resetting it except for deleting the filter instance and applying a new filter instance (which causes me to have to lose a lot of work I’ve already done in that filter instance). Does anyone know if this is a known bug and if there’s a “good” workaround once this has happened ?
    Dirk De jong replied 14 years, 2 months ago 2 Members · 3 Replies
  • Mark Spencer
    May 30, 2012 at 5:06 pm
    Yes you have to first remove the parameter from the rig before you delete the rig.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Dirk De jong
    May 30, 2012 at 5:52 pm
    thanks for confirming – do you know if it’s already been reported as a bug ? Maybe I should report it just in case it hasn’t – seems like it would be worth fixing.
  • Dirk De jong
    July 5, 2012 at 9:27 pm
    FYI – it looks like perhaps this is fixed now in the latest Motion Update – I was able to delete a rig containing a param without first disconnecting the param and the param became free to use in other rigs etc. Glad to see it fixed – twas a real b!tch
