Activity › Forums › Apple Motion › Motion 5 export error -1
  • Motion 5 export error -1
    Posted by Bryan Cantwell on January 16, 2014 at 1:08 pm
    Help! I’m having a major problem with Motion 5… Due to a comedy of errors too long to dwell on, I’ve got a Motion 5 sequence that needs exported. But it just won’t go. Project is all XDCAM HD 1080i60 video, and it’s not using any templates – all transitions & effects were built in the program by the original creator.
    No matter the settings, no matter the format, exporting always fails. The error code it gives me is -1, and it fails at a different frame every time. I’ve tried restarting, clearing RAM preview, and everything else I could think of.
    Any help would be greatly appreciated!
    Bryan Cantwell replied 12 years, 8 months ago 1 Member · 1 Reply
  • Bryan Cantwell
    January 17, 2014 at 3:51 am
    An update of sorts.
    After running every single Apple recommended trouble shooting fix, I’m still in the same boat, but there was a small bright spot.
    Originally, I was working over a network, from a Synology NAS. I moved the project & media to my local drive, cleared as much unnecessary data from the computer as possible, restarted, and got one clean export of the project. One.
    For the greater good, I attempted more exports after the successful one, but all subsequent efforts failed.
    It’s looking like it may be a memory issue. Will update on further research/attempts.
