Activity Forums Apple Final Cut Pro Motion 5 (error-1)
  • Motion 5 (error-1)
    Posted by Chris Oliver on August 15, 2013 at 6:45 pm
    I’ve got Motion 5 and am having a major issue. Get part way through exporting, and (error-1) appears. Can’t export anything!
    I am new to Motion, so may be a simple fix.
    Thanks for the help!!!
    Tim Jones replied 13 years, 1 month ago 2 Members · 1 Reply
  • Tim Jones
    August 15, 2013 at 7:30 pm
    Of course, the first comment is “Have you tried turning it off and back on again?”.
    Check the disk you’re rendering onto. “-1″ is often reporting that the disk is full or cannot be written to. If it’s not a capacity problem, run repair disk (from Disk Utility” and see if that sets thing right.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
