Activity Forums Apple Motion Motion 5 and Vector Graphics?
  • Motion 5 and Vector Graphics?
    Posted by Jade Maxwell on July 19, 2012 at 3:55 pm
    My work ended up getting me Apple Motion 5 which is really fun to mess around with so far. But there are two questions I couldn’t find the answer for when Googling. I’m hoping someone could help.
    1) I have two screens and found the “show Canvas in second monitor” thing and it looks ok, but what’s left on the first monitor has each of the columns file browser/library/inspector, timeline, and timeline itself are either too big or too small width wise. Is there any way to adjust the panels/windows of Motion to my specification? I want to have only the canvas on the second monitor, and the rest on the first, and sorted to how I like. But it stops at a certain width and you can’t go any smaller.
    2) Is there anyway to import a vector graphic, like an Illustrator file, where I can still adjust each individual layers? All the things I found about this pertains to Motion 4.
    When I import an Illustrator file into Motion, it just imports as a picture that has been merged. I had watched a tutorial on something similar to what I want to do, but it was for Motion 4 and they said that with a psd file, you can click and hold over the canvas and you can have the option of adding all layers and such. So I did that by converting the file to psd, and doing the whole click and hover, then import all layers. And it worked! I have all the layers. EXCEPT, now the picture doesn’t show up. 🙁
    Any help would be appreciated. Thanks~
    Jade Maxwell replied 14 years, 1 month ago 2 Members · 12 Replies
  • 12 Replies
  • Mark Spencer
    July 19, 2012 at 4:15 pm
    Sorry, no on both counts. You can, however, with vector artwork, disable “Fixed Resolution’ so that you can scale the layer as large as you like with no loss of resolution.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Jade Maxwell
    July 19, 2012 at 7:32 pm
    🙁 Thanks for the reply.
    I did, however, learn about that fixed resolution thing by watching your tutorial. 🙂
    Do you have any idea why the psd are not showing up when I import as layers though?
  • Mark Spencer
    July 19, 2012 at 7:42 pm
    In Photoshop, make sure the file is 8-bit (not 16) and the color space is RGB (not CMYK or anything else) – if that’s not it, also check that you’ve rasterized any layer effects (glow, stroke, drop shadow, etc.).
    Mark Spencer
  • Jade Maxwell
    July 19, 2012 at 10:53 pm
    It worked! Thank you, you are amazing. 😀
  • Mark Spencer
    July 19, 2012 at 10:58 pm
    So what was the issue? Your solution may help others if you post what it was.
    Mark Spencer
  • Jade Maxwell
    July 20, 2012 at 5:32 pm
    The graphic was done in Illustrator so I had export it as a psd and saved it. But it was saved as a CMYK. I just made sure to save it as RGB. Now the only other problem that I seem to be seeing is that once imported into Motion, the square have stairstep when you zoom in and it looks ragged.
    We’re trying to recreate a pile of paper so there’s a bunch of layers at an angle, and importing it into Motion seems to not keep the quality of a vector graphic.
  • Mark Spencer
    July 20, 2012 at 6:23 pm
    If you resolution independence you have to import the Illustrator file or a .pdf file.
    Mark Spencer
  • Jade Maxwell
    July 20, 2012 at 6:35 pm
    But then we would lost the ability to edit in Motion with the layers, correct?
  • Mark Spencer
    July 20, 2012 at 6:53 pm
    Correct you need to save separate Illustrator files for each layer,
    Mark Spencer
  • Jade Maxwell
    July 20, 2012 at 10:05 pm
    Ok, thanks for your help. I have another question… I’m trying to mess with the particle emitters to kind of do an effect where the stack of paper are going into a computer screen. I’m having trouble making it go on a path I want and stop at a certain point (AKA, when it goes “into” the computer”)
    What’s the best way to do this?
