Activity Forums Apple Motion Motion 5 and Final Cut 7, No transparency being transferred
  • Motion 5 and Final Cut 7, No transparency being transferred
    Posted by Chris Larsen on August 22, 2011 at 4:21 am
    I’m having some sort of alpha channel issue. Exporting from Motion 5 as prores 422 (fcp7 timeline settings), when I go into options color+alpha is the export option, but final cut 7 only shows a black background. My current workaround is to chroma key the black out, but this may not be a viable option for future projects.
    additional notes,
    export option: “Use current settings” creates a file that is unrecognized by final cut 7.
    In the project properties I have set the background to transparent.
    I have tried other variations of prores that have produced the same result.
    Personal Opinion:
    Final Cut X wasn’t ready for release and anyone who uses it is doing Apple a $400 favor by testing for interface/workflow design flaws.
    What FCPX needs: Better Keyframing (window for simple adjustment)
    Magnetic timeline is garbage, any editor proficient in FCP never worried about it anyway. What I could do with the pen tool in 30 seconds in FCP7 takes me 3 times longer to do in FCP 10.
    Colorgrading in FCPX is a joke, keep color alive and return all the necessary tools to use 3rd party softwares. audio editing and filters are also a joke.
    any way… Enough griping help me out if you can, much appreciated.
    Tim Simpson replied 15 years ago 3 Members · 7 Replies
  • 7 Replies
  • Mark Spencer
    August 22, 2011 at 4:27 am
    ProRes 422 does not support an alpha channel. Try ProRes 4444 or Animation, with colors set to Millions+.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Chris Larsen
    August 22, 2011 at 4:34 am
    /facepalm
    Thanks worked perfect.
  • Tim Simpson
    September 21, 2011 at 6:02 pm
    Mark,
    I tried this and it still has a black background in my fcpx project when i import it. I have set the motion 5 to transparency and also
    saved as prores 4444 is their something i am missing.
    I thought this was suppose to be easy as these motion is for placing in fcp on movies.
    I am somewhat new to all this but got a job where i was forced to learn all this.
    Not very stoked on FCPx with all the bugs especially serious playback issues.
    Any help would be much appreciated thanks Tim
  • Mark Spencer
    September 21, 2011 at 6:04 pm
    Tim, Motion 5 is not compatible with FCP 7.
    Mark Spencer
  • Tim Simpson
    September 21, 2011 at 6:15 pm
    I have fcp x and i still can’t get any motion image or movie to show up in fcpx without having a black square box behind it.
    Also note i watched your tutorial on fcpx how to publish features from motion 5 and have them be editable in fxpx, great stuff by the way biut
    when i import a motion 5 movie in and i changed all the features like scale, rotate, ect it still is not editable in fcpx
    once i am done this large tutorail video i have to get fcp7 as i have heard and read that fcp x is filled with bugs and bad stuff.
    Is this just another bug in this program?
    thanks for the quick response.
    Thanks Tim
  • Mark Spencer
    September 21, 2011 at 8:05 pm
    If you want your Motion project in FCP X you need to publish it as a generator.
    Where have you heard FCPX is filled with bugs? That has not been my experience at all.
    The workflow between Motion 5 and FCP X is totally different than Motion 4 and FCP 7. It works, you just need to know what to do.
    Mark Spencer
  • Tim Simpson
    September 22, 2011 at 3:41 pm
    Mark,
    Thanks I am actually having serious performance issues with fcpx.
    Just on playing back, the video slows down alot and then the video and sound do not match and this has created a ton of problems in this very large dentistry tutorial project and am very frustrated because when i go to show the dr. the main point titles don’t show up when he views the project to make final approvals.
    I have went on FCPX comments and read more then half on so many complaints. I am stuck now to finish this in FCPX since i am 80% done.
    Could you give me a brief rundown on how to publish a generator. I see that when you first open it gives option of making a fcpx generator but now my motion movie is done as a regular project. so do i have to do it all over as selecting create a generator for fcpx now?
    Any help so i can finish this up.
    also i have a ton of other video projects to do for the Dr. so would you recommdened i get fcp7? Also called apple today and they said they have a new fcpx and motion 5 update that might fix some of these issues hopefully. downloading now. Sorry for the long post just need to get this done.
    thanks Tim
