Activity Forums Apple Motion Motion 4 VS Motion 5 – Same project, different results…
  • Motion 4 VS Motion 5 – Same project, different results…
    Posted by João Cunha on March 27, 2012 at 12:02 pm
    Hi.
    I’m having a major problem that I don’t know how to solve. I have a project that was made in Motion 4 with effects that are also available in Motion 5. I’ve opened the project in Mo5 and the result after exporting the video is a bit different. The values of every attribute are the same so I don’t know what is happening.
    I’m talking about a shinny animated effect done with a emitter.
    Is there any option or tweak to get exactly the same result between the 2 versions of the software?
    Thank you!
    João Cunha replied 14 years, 5 months ago 2 Members · 2 Replies
  • Mark Spencer
    March 27, 2012 at 2:09 pm
    Motion 5 is fully color-managed and works in a different color space than Motion 4 (it’s more “accurate”) – so you’ll likely not be able to match exports exactly between the two. You can try adding a Gamma filter to the affected layers and adjust it to 1.8 or 2.2 to see if that helps.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • João Cunha
    March 27, 2012 at 2:29 pm
    I’ve tried what you said and it didn’t work. I’m talking about a emitter that has a star shape and a blur associated to it. In motion 4 we can see the stars with the blur but also they are clear. In motion 5, the blur simply is too aggressive and causes a “cloud” around the star.
    I’ve already compared every value and everything is the same…
