Activity › Forums › Apple Motion › Motion 4 ‘Quitting Unexpectedly”
  • Motion 4 ‘Quitting Unexpectedly”
    Posted by Matt Frame on September 3, 2011 at 11:04 pm
    HI, I recently installed Motion 5 as I assumed (incorrectly) that it would work with Final Cut Studio 3. After realizing my moronic error, I uninstalled 5 and reinstalled 4 but now there is a major issue. When I try to open Motion 4, it crashes almost immediately. I receive a ‘Motion Quit Unexpectedly’ message. If I try to send a clip to motion from FCP Motion 4 will open for a moment, then crash. FCP then quickly crashes afterwards. I have uninstalled and re-installed Final Cut Studio twice now in hopes that would clear the issue but to no avail. Does any good samaritan out there read error code and can give me some idea as to what the issue is?
    Thanks much in advance!
    Here are the problem details:
    Process: Motion [8268]
    Path: /Applications/Motion.app/Contents/MacOS/Motion
    Identifier: com.apple.motion
    Version: 4.0.0 (687)
    Build Info: Motion-6870000~22
    Code Type: X86 (Native)
    Parent Process: launchd [116]
    Date/Time: 2011-09-03 15:51:57.116 -0700
    OS Version: Mac OS X 10.6.7 (10J869)
    Report Version: 6
    Interval Since Last Report: 5419809 sec
    Crashes Since Last Report: 59
    Per-App Interval Since Last Report: 1388 sec
    Per-App Crashes Since Last Report: 26
    Anonymous UUID: BF22913B-00EC-4626-A6C0-B0E6D89ADACB
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000036e63dbe
    Crashed Thread: 15
    Thread 0: Dispatch queue: com.apple.main-thread
    0 libSystem.B.dylib 0x937e709a mach_msg_trap + 10
    1 libSystem.B.dylib 0x937e7807 mach_msg + 68
    2 com.apple.CoreGraphics 0x92619759 _CGSSetWindowShapeInline + 240
    3 com.apple.CoreGraphics 0x92612e01 CGSShapeWindow + 1498
    4 com.apple.CoreGraphics 0x92612823 CGSSetWindowShapeWithWeighting + 76
    5 com.apple.AppKit 0x987a8aba _NXPlaceWindow + 183
    6 com.apple.AppKit 0x987a7f21 -[NSWindow _setFrame:updateBorderViewSize:] + 660
    7 com.apple.AppKit 0x987a76f4 -[NSWindow _oldPlaceWindow:] + 1205
    8 com.apple.AppKit 0x987a6a64 -[NSWindow _setFrameCommon:display:stashSize:] + 1790
    9 com.apple.AppKit 0x987a635f -[NSWindow setFrame:display:] + 78
    10 com.apple.AppKit 0x9883b909 -[NSThemeFrame _growWindowReshapeContentAndToolbarView:animate:] + 3368
    11 com.apple.AppKit 0x9883ab9f -[NSThemeFrame _reshapeContentAndToolbarView:resizeWindow:animate:] + 415
    12 com.apple.AppKit 0x9883964a -[NSThemeFrame _showHideToolbar:resizeWindow:animate:] + 421
    13 com.apple.AppKit 0x98839498 -[NSThemeFrame _showToolbarWithAnimation:] + 195
    14 com.apple.AppKit 0x9881ffa6 -[NSWindow _showToolbar:animate:] + 117
    15 com.apple.AppKit 0x9881e249 -[NSWindow setToolbar:] + 738
    16 com.apple.ozone.framework 0x00ca9045 -[OZCanvasView awakeFromNib] + 741
    17 com.apple.CoreFoundation 0x92f899b4 -[NSSet makeObjectsPerformSelector:] + 196
    18 com.apple.AppKit 0x9878721c -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 1566
    19 com.apple.AppKit 0x987851f4 loadNib + 257
    20 com.apple.AppKit 0x98784848 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 831
    21 com.apple.AppKit 0x987844fe +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 158
    22 com.apple.AppKit 0x988141e7 -[NSWindowController loadWindow] + 223
    23 com.apple.AppKit 0x987aaf76 -[NSWindowController window] + 89
    24 com.apple.ozone.framework 0x0082acbc -[OZObjCDocument showWindows] + 156
    25 com.apple.AppKit 0x98b29712 -[NSDocumentController(NSDeprecated) openUntitledDocumentOfType:display:] + 148
    26 com.apple.ozone.framework 0x00ac9909 -[OZDocumentController openUntitledDocumentOfType:display:] + 233
    27 com.apple.ozone.framework 0x00ac9ab0 -[OZDocumentController newDocument:] + 80
    28 com.apple.ozone.framework 0x00b32502 -[OZWelcomeScreenController performClose:] + 338
    29 com.apple.AppKit 0x98805c46 -[NSApplication sendAction:to:from:] + 112
    30 com.apple.prokit 0x001bd464 -[NSProApplication sendAction:to:from:] + 127
    31 com.apple.AppKit 0x988e5465 -[NSControl sendAction:to:] + 108
    32 com.apple.AppKit 0x988e0f12 -[NSCell _sendActionFrom:] + 169
    33 com.apple.AppKit 0x988e0209 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 1808
    34 com.apple.AppKit 0x989358a1 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 524
    35 com.apple.prokit 0x0020226e -[NSProButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 539
    36 com.apple.AppKit 0x988dec5f -[NSControl mouseDown:] + 812
    37 com.apple.AppKit 0x988dcc68 -[NSWindow sendEvent:] + 5549
    38 com.apple.prokit 0x001e5a40 -[NSProWindow sendEvent:] + 264
    39 com.apple.AppKit 0x987f5817 -[NSApplication sendEvent:] + 6431
    40 com.apple.prokit 0x001c0090 -[NSProApplication sendEvent:] + 1901
    41 com.apple.motion 0x0000848b 0x1000 + 29835
    42 com.apple.AppKit 0x987892a7 -[NSApplication run] + 917
    43 com.apple.prokit 0x001c0446 NSProApplicationMain + 326
    44 com.apple.motion 0x00005881 0x1000 + 18561
    45 com.apple.motion 0x00002ad6 0x1000 + 6870
    Thread 1: Dispatch queue: com.apple.libdispatch-manager
    0 libSystem.B.dylib 0x9380d922 kevent + 10
    1 libSystem.B.dylib 0x9380e03c _dispatch_mgr_invoke + 215
    2 libSystem.B.dylib 0x9380d4f9 _dispatch_queue_invoke + 163
    3 libSystem.B.dylib 0x9380d29e _dispatch_worker_thread2 + 240
    4 libSystem.B.dylib 0x9380cd21 _pthread_wqthread + 390
    5 libSystem.B.dylib 0x9380cb66 start_wqthread + 30
    Thread 2: com.apple.CFSocket.private
    0 libSystem.B.dylib 0x93806066 select$DARWIN_EXTSN + 10
    1 com.apple.CoreFoundation 0x92f99c83 __CFSocketManager + 1091
    2 libSystem.B.dylib 0x938147fd _pthread_start + 345
    3 libSystem.B.dylib 0x93814682 thread_start + 34
    Thread 3:
    0 libSystem.B.dylib 0x937e70fa semaphore_timedwait_signal_trap + 10
    1 libSystem.B.dylib 0x93814c85 _pthread_cond_wait + 1066
    2 libSystem.B.dylib 0x93843aa8 pthread_cond_timedwait_relative_np + 47
    3 …ple.CoreServices.CarbonCore 0x975ffe3d TSWaitOnConditionTimedRelative + 242
    4 …ple.CoreServices.CarbonCore 0x975ffb7b TSWaitOnSemaphoreCommon + 511
    5 …ickTimeComponents.component 0x909e6591 ReadSchedulerThreadEntryPoint + 4698
    6 libSystem.B.dylib 0x938147fd _pthread_start + 345
    7 libSystem.B.dylib 0x93814682 thread_start + 34
    Thread 4:
    5 …ple.CoreServices.CarbonCore 0x9765a6ee AIOFileThread(void*) + 1127
    Thread 5: QTKit: QTSurfaceRendererScheduledDisplayThread
    2 com.apple.CoreFoundation 0x92f5a37f __CFRunLoopRun + 2079
    3 com.apple.CoreFoundation 0x92f59464 CFRunLoopRunSpecific + 452
    4 com.apple.CoreFoundation 0x92f5f3a4 CFRunLoopRun + 84
    5 com.apple.QTKit 0x915d3406 QTSurfaceRendererScheduledDisplayThread + 164
    Thread 6: QTKit: QTVisualContextImageProviderWorkLoop
    5 com.apple.QTKit 0x915cf645 QTVisualContextImageProviderWorkLoop + 128
    Thread 7:
    0 libSystem.B.dylib 0x937e70e2 semaphore_wait_signal_trap + 10
    1 libSystem.B.dylib 0x93814c9c _pthread_cond_wait + 1089
    2 libSystem.B.dylib 0x9385d45f pthread_cond_wait + 48
    3 com.apple.AppleProResCodec 0x2192d40b IcpDecompressorComponentDispatch + 1771
    4 libSystem.B.dylib 0x938147fd _pthread_start + 345
    Thread 8:
    Thread 9:
    5 …ple.CoreServices.CarbonCore 0x97623deb TimerThread + 97
    Thread 10:
    5 …ple.CoreServices.CarbonCore 0x9769309e DeferredTaskThread + 84
    Thread 11:
    5 com.apple.QuickTime 0x9937e09b VideoDecodeThread + 83
    Thread 12:
    0 libSystem.B.dylib 0x93815046 __semwait_signal + 10
    1 libSystem.B.dylib 0x93840ec5 nanosleep$UNIX2003 + 188
    2 libSystem.B.dylib 0x93840e03 usleep$UNIX2003 + 61
    3 com.apple.AppKit 0x98930fe1 -[NSUIHeartBeat _heartBeatThread:] + 2039
    4 com.apple.Foundation 0x9710cad0 -[NSThread main] + 45
    5 com.apple.Foundation 0x9710ca80 __NSThread__main__ + 1499
    Thread 13:
    0 libSystem.B.dylib 0x9380c9b2 __workq_kernreturn + 10
    1 libSystem.B.dylib 0x9380cf48 _pthread_wqthread + 941
    2 libSystem.B.dylib 0x9380cb66 start_wqthread + 30
    Thread 14:
    1 libSystem.B.dylib 0x93814d02 _pthread_cond_wait + 1191
    2 libSystem.B.dylib 0x93816998 pthread_cond_wait$UNIX2003 + 73
    3 com.apple.ozone.framework 0x00a217ab OZExecutionUnit::executeLoop() + 75
    4 com.apple.ozone.framework 0x00a218ae OZExecutionUnit::executeLoopWrapper(void*) + 94
    5 com.apple.procore.framework 0x019aa0a8 PCThread::startup(void*) + 18
    Thread 15 Crashed:
    0 libSystem.B.dylib 0x937ec352 tiny_malloc_from_free_list + 741
    1 libSystem.B.dylib 0x937eb2a1 szone_malloc_should_clear + 263
    2 libSystem.B.dylib 0x937eb148 malloc_zone_malloc + 81
    3 libSystem.B.dylib 0x937e9218 malloc + 50
    4 libstdc++.6.dylib 0x95896617 operator new(unsigned long) + 36
    5 com.apple.Helium.HeliumRender 0x01e0bf47 HGSolidColor::HGSolidColor() + 55
    6 com.apple.ProGraphics 0x014cd418 LockAndRenderHardware(HGGLRenderer*, HGGLTexture**, HGRect, HGFormat, HGNode*) + 264
    7 com.apple.ProGraphics 0x014ceb32 PGHelium::renderNodeToTexture(HGGLRenderer*, HGNode*, PCRect, PCPixelFormat::ChannelOrder, bool) + 354
    8 com.apple.ozone.framework 0x009e61a3 GLRenderer::renderImageFromNode(HGNode*, OZRenderParams&, HGRenderer*) + 387
    9 com.apple.ozone.framework 0x009ea6ac GLRenderer::render(OZScene*, OZRenderParams&) + 4892
    10 com.apple.ozone.framework 0x00a23718 OZRenderUnit::processRenderInstruction(OZRenderInstruction*) + 2312
    11 com.apple.ozone.framework 0x00a2402c OZRenderUnit::execute() + 188
    12 com.apple.ozone.framework 0x00a21825 OZExecutionUnit::executeLoop() + 197
    13 com.apple.ozone.framework 0x00a218ae OZExecutionUnit::executeLoopWrapper(void*) + 94
    14 com.apple.procore.framework 0x019aa0a8 PCThread::startup(void*) + 18
    15 libSystem.B.dylib 0x938147fd _pthread_start + 345
    16 libSystem.B.dylib 0x93814682 thread_start + 34
    Thread 16:
    Thread 17:
    Thread 18:
    Thread 15 crashed with X86 Thread State (32-bit):
    eax: 0x000fff20 ebx: 0x36d63ea0 ecx: 0x0000000a edx: 0xfffffbff
    edi: 0x36d64c70 esi: 0x0000fff2 ebp: 0xb08a2578 esp: 0xb08a24f0
    ss: 0x0000001f efl: 0x00010202 eip: 0x937ec352 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
    cr2: 0x36e63dbe
    Binary Images:
    0x1000 – 0x3ffe7 com.apple.motion 4.0.0 (687) <810547A6-E634-5300-8568-7DB2247F0A55> /Applications/Motion.app/Contents/MacOS/Motion
    0x143000 – 0x179ff6 com.apple.proinspector.framework 3.1.0 (711) /Library/Application Support/ProApps/SharedA/Frameworks/ProInspector.framework/Versions/A/ProInspector
    0x19c000 – 0x3d4fff com.apple.prokit 7.0 (1331) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    0x4dc000 – 0x4ebfff com.apple.AERegistration 1.2 (77) <0C4C1300-9E3A-E2A1-4507-380C2544B223> /Applications/Motion.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
    0x4ff000 – 0x50bff7 com.apple.PluginManager 1.7.5 (50) /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
    0x515000 – 0x52efff com.apple.promath.framework 4.0.0 (687) <305AE865-1D4F-02D5-E8D3-F6BC8C217C97> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMath.framework/Versions/A/ProMath
    0x538000 – 0x53ffff com.apple.AEProfiling 1.2 (22) <50FD5623-D2C1-8102-FD41-D8E745E08353> /Applications/Motion.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    0x549000 – 0x6adff2 com.apple.ProMedia 4.0.0 (687) <0F9638D9-30E5-6F10-1450-CEC204C2E3E6> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMedia.framework/Versions/A/ProMedia
    0x71b000 – 0xff2fe2 com.apple.ozone.framework 4.0.0 (687) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Ozone.framework/Versions/A/Ozone
    0x148e000 – 0x14f6fff com.apple.ProGraphics 4.0.0 (687) <66BC8748-D129-AF15-637B-4D7C168A7944> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProGraphics.framework/Versions/A/ProGraphics
    0x1612000 – 0x1793ff2 com.apple.Lithium 4.0.0 (687) <1690BA2F-1363-9D9B-D105-F519F9D4AE12> /Library/Application Support/ProApps/SharedA/Frameworks/Lithium.framework/Versions/A/Lithium
    0x1816000 – 0x18e3ff3 com.apple.prochannel.framework 3.1.0 (711) <62B98BC2-5E32-20E4-0FB1-5A4417ED8899> /Library/Application Support/ProApps/SharedA/Frameworks/ProChannel.framework/Versions/A/ProChannel
    0x1982000 – 0x1a1fff8 com.apple.procore.framework 4.0.2 (757) /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
    0x1a5f000 – 0x1a7dfef com.apple.XSKey 1.0.0 (52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
    0x1a8c000 – 0x1a95ff7 com.apple.finalcutstudio.prometadatasupport 0.6 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
    0x1a9d000 – 0x1b70fff org.python.python 2.5.4 (2.5) <2425B12D-D1AB-C0EE-D6EF-64D5600F6905> /System/Library/Frameworks/Python.framework/Versions/2.5/Python
    0x1bb0000 – 0x1c14fe2 com.apple.LiveType.framework 2.1.4 (2.1.4) /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
    0x1c34000 – 0x1c35ff7 com.apple.Helium 3.0.3 (359) <1B909921-EE16-B317-3670-B0C63C70F01B> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Helium
    0x1c3a000 – 0x1c3aff7 com.apple.iokit.dvcomponentglue 1.9.9 (1.9.9) <2BA05DB9-D847-CBC7-42D6-A9D96D7E1ED2> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0x1c3e000 – 0x1c8affb com.apple.audio.midi.CoreMIDI 1.7.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x1caf000 – 0x1cc0ff7 com.apple.fxplugframework 1.2.3 (1.2.3) <033FEA79-E666-D319-5BD5-25A9A4331190> /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
    0x1cd3000 – 0x1ceafe7 libedit.2.dylib 2.11.0 (compatibility 2.0.0) <45688CB7-9BE4-5D1B-C209-A414EE98C5D2> /usr/lib/libedit.2.dylib
    0x1cf7000 – 0x1d08fff com.apple.RetimingMath 4.0.0 (687) <6EFB289B-0AE8-64C2-5B5E-0674DA51E905> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/RetimingMath.framework/Versions/A/RetimingMath
    0x1d1d000 – 0x1d1efff com.apple.FxHeliumImage 4.0.0 (1.0) <62A25655-AB02-73F7-FE2B-21823D2D4BA4> /Library/Application Support/ProApps/SharedA/Frameworks/FxHeliumImage.framework/Versions/A/FxHeliumImage
    0x1d24000 – 0x1e76fec com.apple.Helium.HeliumRender 2.0.3 (359) <93D90702-A8F2-B483-818A-6C5E85D7000F> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
    0x1ecf000 – 0x1f84fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
    0x2788000 – 0x27acfe7 GLRendererFloat ??? (???) <0C6A1BCF-97F0-F7D6-C840-2991681BB67C> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x87a0000 – 0x8918fe7 GLEngine ??? (???) <0E1DF3E4-0EEE-9FD8-8F52-FFFCF0DF23A7> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    0x894a000 – 0x8d4ffe7 libclh.dylib 3.1.1 C (3.1.1) <04502F95-931E-0AAF-7296-4624C7F8DE8B> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
    0x8e72000 – 0x8e84fff com.apple.motion.Text 4.0.0 (687) <41EB0254-7D99-E54B-438D-372FD449425D> /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Text.ozp/Contents/MacOS/Text
    0x8e91000 – 0x8e96ffb com.apple.fxmetaplug.ImageUnit 1.2.2 (1.2.2) <874EE8A7-B644-32C8-D8E2-1E4EA379C31B> /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
    0x8e9e000 – 0x8ea6ff7 com.apple.proapps.mrcheckpro 1.4 (359) <353F1A07-BA95-60CD-D083-4537D209BB69> /Applications/Motion.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
    0x8eef000 – 0x8ef1ff3 com.apple.LiveType.component 2.1.4 (2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0x8ef7000 – 0x8f3dffb com.apple.motion.component 1.0 (687) /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    0x8f43000 – 0x8f45ff7 Motion 687.0.0 (compatibility 1.0.0) /Library/Frameworks/Motion.framework/Versions/A/Motion
    0x9005000 – 0x919aff7 com.apple.motion.Behaviors 4.0.0 (687) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Behaviors.ozp/Contents/MacOS/Behaviors
    0x9239000 – 0x9284ff4 com.apple.Bloodhound 4.0.0 (687) <1E9D1F25-9333-F9EC-B42C-B0B7D15D7098> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Bloodhound.framework/Versions/A/Bloodhound
    0x92af000 – 0x944bff8 com.apple.motion.Particles 4.0.0 (687) /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Particles.ozp/Contents/MacOS/Particles
    0x94a5000 – 0x9852ff2 com.apple.motion.TextFramework 4.0.0 (687) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/TextFramework.framework/Versions/A/TextFramework
    0x990e000 – 0x9943ff7 com.apple.prokit.SnowLeopardPanels 7.0 (1331) /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/Resources/SnowLeopardPanels.bundle/Contents/MacOS/SnowLeopardPanels
    0xa594000 – 0xa595ff7 ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    0xd93c000 – 0xd93cff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
    0xe7ac000 – 0xe7b0ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0xe927000 – 0xe92dffb com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <82BFF5E9-2B0E-FE8B-8370-445DD94DA434> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0xf22c000 – 0xf23dfe7 com.apple.FCP Uncompressed 422.component 1.6.1 (1.6.1) <62C290FB-2735-60C4-CE88-7ECB0DE6EDB3> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    0xf4fd000 – 0xf4fffff com.apple.Helium.HCache 2.1.0 (359) <669FD4C8-B9A0-549E-EC32-C49718676C34> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
    0xf549000 – 0xf562fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    0xf74d000 – 0xf771ff7 com.apple.AppleAVCIntraCodec 1.0 (16) <8A1A4CEE-1610-EECE-74DA-D2AF42825E6D> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
    0xf77c000 – 0xf7b8fe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1756.15) <9C48FD18-B6B8-10FA-3B09-47915626A73C> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    0xfe87000 – 0xfebefe7 com.apple.DVCPROHDCodec 1.5 (237) <5BA42205-5AEE-73BB-A7DE-5417EF028D5B> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    0xffb3000 – 0xffcefef com.apple.AppleIntermediateCodec 1.3.2 (153) /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    0xffd4000 – 0xffe7fe3 com.apple.IMXCodec 1.4 (155) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    0x10000000 – 0x10060fef com.apple.proapps.AudioMixEngine 2.0 (68) /Applications/Motion.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    0x21923000 – 0x21990fe7 com.apple.AppleProResCodec 2.0 (224) /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
    0x22700000 – 0x2277afef com.apple.AppleVAH264HW.component 2.0 (1.0) <6DA1BA82-A66D-6098-7989-965ADF1E9C7C> /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
    0x2283d000 – 0x228ecfe3 com.apple.AppleHDVCodec 1.6 (229) /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    0x8f0c7000 – 0x8f811ff7 com.apple.GeForceGLDriver 1.6.26 (6.2.6) <90BBC89A-6A56-C4B7-F848-432908CDE14D> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
    0x8fe00000 – 0x8fe4162b dyld 132.1 (???) <28F0312C-0678-159E-34E2-9A4E3DEADB20> /usr/lib/dyld
    0x90003000 – 0x90011ff7 com.apple.opengl 1.6.12 (1.6.12) <81AEF74E-E33A-B021-9CDB-6199104105FF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x90012000 – 0x90013ff7 com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
    0x90014000 – 0x90140ffb com.apple.MediaToolbox 0.484.20 (484.20) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x90141000 – 0x90172ff7 libGLImage.dylib ??? (???) <1AF72191-087A-5D75-B3B9-3F537315F635> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x90173000 – 0x90197ff7 libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x90198000 – 0x901e1fe7 libTIFF.dylib ??? (???) <5CE284EC-F637-EDBB-FDB3-61E86407CBB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x9025d000 – 0x9026dff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
    0x902bf000 – 0x902bfff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x902c0000 – 0x9030dfeb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
    0x9030e000 – 0x90326ff7 com.apple.CFOpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x90327000 – 0x903f8fe3 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <41417F73-42C5-FFC3-E7A1-EF94602CDCD6> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
    0x903f9000 – 0x90421ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
    0x9042e000 – 0x91381fe3 com.apple.QuickTimeComponents.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x91382000 – 0x913bfff7 com.apple.CoreMedia 0.484.20 (484.20) <105DDB24-E45F-5473-99E1-B09FDEAE4500> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x913c0000 – 0x91479fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
    0x9147a000 – 0x914fcffb SecurityFoundation ??? (???) <006B3166-E7E2-F763-04FC-3DD458C14F5F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x914fd000 – 0x91640fef com.apple.QTKit 7.6.6 (1756.15) <32C49374-14BC-53E7-FBFF-E11B42A41F56> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x91641000 – 0x91681ff3 com.apple.securityinterface 4.0.1 (40418) <26D84A83-F5B9-93CF-71BB-0712698181EE> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x91682000 – 0x91b3bffb com.apple.VideoToolbox 0.484.20 (484.20) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x91b3c000 – 0x91b4dff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x91bef000 – 0x91c97ffb com.apple.QD 3.36 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x91c98000 – 0x91c9bffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x91c9c000 – 0x91d9dfe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) /usr/lib/libxml2.2.dylib
    0x91d9e000 – 0x91d9eff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x91d9f000 – 0x91f9dff3 com.apple.JavaScriptCore 6533.20 (6533.20.20) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x91f9e000 – 0x91fbffe7 com.apple.opencl 12.3.6 (12.3.6) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x91fc0000 – 0x91fc0ff7 com.apple.Carbon 150 (152) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x91fc1000 – 0x91ff9fe7 libncurses.5.4.dylib 5.4.0 (compatibility 5.4.0) <8776C654-D54E-9756-A58D-74738A4E9497> /usr/lib/libncurses.5.4.dylib
    0x92250000 – 0x92251ff7 com.apple.audio.units.AudioUnit 1.6.6 (1.6.6) <253E9552-5CEA-0D5A-1EDA-3B8F669B79EA> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x9239b000 – 0x923b0fff com.apple.ImageCapture 6.0.2 (6.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x923b1000 – 0x92402ff7 com.apple.HIServices 1.8.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x92403000 – 0x9247efff com.apple.AppleVAFramework 4.10.23 (4.10.23) <57B7C626-F344-AB15-8556-00425FA765DE> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x9247f000 – 0x924cfff7 com.apple.framework.familycontrols 2.0.2 (2020) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
    0x924d0000 – 0x92513ff7 com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x92514000 – 0x9258bff3 com.apple.backup.framework 1.2.2 (1.2.2) /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x9258c000 – 0x925c5fe7 com.apple.bom 10.0 (164) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x925c6000 – 0x92603ff7 com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x92604000 – 0x92df3557 com.apple.CoreGraphics 1.545.0 (???) <8A4CB0D9-1001-0F62-4DA4-B8AB3B45E226> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x92df4000 – 0x92dfefe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x92dff000 – 0x92e46ffb com.apple.CoreMediaIOServices 134.0 (1160) <4CD78557-3CDA-A4B5-33CB-BBB876B4463D> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
    0x92e47000 – 0x92e49ff7 com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x92e91000 – 0x92f0aff7 com.apple.PDFKit 2.5.1 (2.5.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x92f0b000 – 0x92f15ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x92f1d000 – 0x93098fe7 com.apple.CoreFoundation 6.6.4 (550.42) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x93099000 – 0x930abff7 com.apple.MultitouchSupport.framework 207.10 (207.10) /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x930ac000 – 0x930dfff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x93123000 – 0x931fdffb com.apple.DesktopServices 1.5.10 (1.5.10) <2BA08DD4-35A2-A0FF-ADEA-B381F0CEEB81> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x93200000 – 0x93203fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
    0x932ae000 – 0x932bbff7 com.apple.AppleFSCompression 24.4 (1.0) <6D696284-020B-7F5C-226D-B820F0E981D2> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x932bc000 – 0x93627ff7 com.apple.QuartzCore 1.6.3 (227.36) <8E927524-EB0A-D5BA-C2E4-FA26FE4C428A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x936aa000 – 0x936b0fff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x936b1000 – 0x936b1ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x93774000 – 0x93774ff7 com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x93775000 – 0x937e4ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x937e5000 – 0x937e5ff7 com.apple.Cocoa 6.6 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x937e6000 – 0x9398dff7 libSystem.B.dylib 125.2.10 (compatibility 1.0.0) /usr/lib/libSystem.B.dylib
    0x9398e000 – 0x939b8ff7 com.apple.shortcut 1.1 (1.1) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x939b9000 – 0x939c7fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
    0x939c8000 – 0x93affff7 com.apple.CoreAUC 6.04.05 (6.04.05) <4A2BEE1A-A74A-746B-EFA6-470CD3354252> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x93b00000 – 0x93f52ffb com.apple.RawCamera.bundle 3.7.0 (569) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x93fa8000 – 0x94073fef com.apple.CoreServices.OSServices 359 (359) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x94074000 – 0x9411efe7 com.apple.CFNetwork 454.11.12 (454.11.12) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x9411f000 – 0x941bcfe3 com.apple.LaunchServices 362.2 (362.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x941bd000 – 0x941dcff7 com.apple.CoreVideo 1.6.2 (45.6) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x941e8000 – 0x941f1ff7 com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x94238000 – 0x9424cfe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
    0x9424d000 – 0x942dffe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x942e0000 – 0x9435afff com.apple.audio.CoreAudio 3.2.6 (3.2.6) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x94dfd000 – 0x94e08ff7 libGL.dylib ??? (???) <4425B9AA-B494-A336-EABB-6BBC9FF4EC4F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x94e09000 – 0x94e4aff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <95079B56-0B7B-F114-5C43-5220DBE0FBB1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x94e72000 – 0x94e72ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x94e76000 – 0x94e7aff7 libGFXShared.dylib ??? (???) <4F2199F0-320F-0B59-0380-D3131D644CBA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x94e7b000 – 0x94ec1ff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
    0x94ec2000 – 0x951e6fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x95415000 – 0x95417ff7 libRadiance.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x954cd000 – 0x954d8ff7 com.apple.CrashReporterSupport 10.6.7 (258) <71CC59D1-E197-7431-5973-2C079A749257> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x954d9000 – 0x9573efeb com.apple.security 6.1.1 (37594) <251BA05D-6F3D-F687-77C2-15E52539F308> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x9573f000 – 0x95747ff7 com.apple.DisplayServicesFW 2.3.0 (283) <48D94761-7340-D029-99E3-9BE0262FAF22> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
    0x95748000 – 0x95780ff7 com.apple.LDAPFramework 2.0 (120.1) <001A70A8-3984-8E19-77A8-758893CC128C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x95781000 – 0x9579dfe3 com.apple.openscripting 1.3.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x9579e000 – 0x957b0ff7 com.apple.CoreMediaAuthoring 0.706 (706) <81D68084-D7BD-E52E-9B1C-C8EC0FCECE3C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
    0x957b6000 – 0x957efff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <90C5DE81-1BEF-D807-A898-0FC19BDD14EC> /usr/lib/libcups.2.dylib
    0x957f0000 – 0x95820ff7 com.apple.MeshKit 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
    0x95821000 – 0x95825ff7 IOSurface ??? (???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x9582e000 – 0x95838ff7 com.apple.HelpData 2.0.5 (34.1.1) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x9584c000 – 0x958b6fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
    0x95a1a000 – 0x95b56ff7 com.apple.audio.toolbox.AudioToolbox 1.6.6 (1.6.6) <781018FB-474B-E09C-D419-5BFF80590A10> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x95b79000 – 0x95c57fef com.apple.QuickTimeMPEG4.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x95c58000 – 0x9606eff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x9606f000 – 0x96096ff7 com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
    0x96148000 – 0x96183feb libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x9619d000 – 0x961e1ff3 com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x964dc000 – 0x96593feb libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x96594000 – 0x965cafff libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
    0x966a8000 – 0x96702fe7 com.apple.CorePDF 1.3 (1.3) <696ADD5F-C038-A63B-4732-82E4109379D7> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
    0x96703000 – 0x96831fe7 com.apple.CoreData 102.1 (251) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x96832000 – 0x96912fe7 com.apple.vImage 4.1 (4.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x96913000 – 0x969cffff com.apple.ColorSync 4.6.6 (4.6.6) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x969d0000 – 0x96a4dff7 com.apple.iLifeMediaBrowser 2.5.4 (468.1.1) <3B7F5895-B48D-A2E0-D708-58EC58EB9514> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
    0x96a4e000 – 0x96a92fe7 com.apple.Metadata 10.6.3 (507.15) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x96a93000 – 0x96b9fff7 libGLProgrammability.dylib ??? (???) <2D172B4E-432F-D18E-EA99-3BD56DBE7649> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x96bf1000 – 0x96c24ffb libTrueTypeScaler.dylib ??? (???) <574C2C51-65EC-7D2A-086D-C9312287DE22> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x96c25000 – 0x96c82ff7 com.apple.framework.IOKit 2.0 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x96c83000 – 0x96e65fff com.apple.imageKit 2.0.3 (1.0) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
    0x96e7f000 – 0x96e84ff7 com.apple.OpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x96e85000 – 0x96e8cff3 com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x96e8d000 – 0x96e8fff7 com.apple.QuickTimeH264.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x96e90000 – 0x96eabff7 libPng.dylib ??? (???) <65E824F7-523A-CC34-ABDD-2A3B12DE1CA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x96eac000 – 0x970b3feb com.apple.AddressBook.framework 5.0.4 (883) /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
    0x970b4000 – 0x970d6fef com.apple.DirectoryService.Framework 3.6 (621.11) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x970d7000 – 0x970e4ff7 com.apple.NetFS 3.2.2 (3.2.2) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x970e5000 – 0x970f5ff7 com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
    0x970f6000 – 0x97369fe7 com.apple.Foundation 6.6.6 (751.53) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x9736a000 – 0x973ceffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x973d4000 – 0x973f4fe7 libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
    0x973f5000 – 0x97577fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libicucore.A.dylib
    0x97578000 – 0x975b8ff7 com.apple.ImageCaptureCore 1.0.4 (1.0.4) /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
    0x975b9000 – 0x978d9ff3 com.apple.CoreServices.CarbonCore 861.34 (861.34) <3DA9098F-B71B-4BDE-5DE5-4B76C49158EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x978da000 – 0x9793bfe7 com.apple.CoreText 3.151.8 (???) <6F5D6C49-4693-B9B7-6612-832E8F155747> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x9794c000 – 0x97d81ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x97d82000 – 0x97dc4ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x97dc5000 – 0x97e1bff7 com.apple.MeshKitRuntime 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime.framework/Versions/A/MeshKitRuntime
    0x97f20000 – 0x97f26fe7 com.apple.CommerceCore 1.0 (9) <928FCA4F-1366-AE18-CF67-87C79F5DAC21> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x97f68000 – 0x98016ff3 com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x9802b000 – 0x98037ff7 libkxld.dylib ??? (???) /usr/lib/system/libkxld.dylib
    0x98038000 – 0x980b8feb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x980b9000 – 0x98273feb com.apple.ImageIO.framework 3.0.4 (3.0.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x982e3000 – 0x983e5fef com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
    0x98404000 – 0x98423fe3 libexpat.1.dylib 7.2.0 (compatibility 7.0.0) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
    0x98424000 – 0x984bfff7 com.apple.ApplicationServices.ATS 4.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x984c0000 – 0x984e6ffb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x986c4000 – 0x986fbfe7 libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
    0x986fc000 – 0x9873aff7 com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x9873b000 – 0x98746ff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <4560936D-7730-5DD2-BFD7-95270DDC210A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x98774000 – 0x98774ff7 liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
    0x9877d000 – 0x9877eff7 com.apple.TrustEvaluationAgent 1.1 (1) /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x9877f000 – 0x9905fff7 com.apple.AppKit 6.6.7 (1038.35) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x99060000 – 0x9928bff3 com.apple.QuartzComposer 4.2 ({156.28}) <08AF01DC-110D-9443-3916-699DBDED0149> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x9928c000 – 0x992faff7 com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
    0x992fb000 – 0x995f4fef com.apple.QuickTime 7.6.6 (1756.15) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x995f5000 – 0x995f8ff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x995f9000 – 0x99691fe7 edu.mit.Kerberos 6.5.11 (6.5.11) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x99787000 – 0x9988bfe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) /usr/lib/libcrypto.0.9.8.dylib
    0x9988c000 – 0x998e4fe7 com.apple.datadetectorscore 2.0 (80.7) <58C659CA-72CC-31D2-9732-09BF1A0CAAF6> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x998e5000 – 0x99992fe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) /usr/lib/libobjc.A.dylib
    0x99993000 – 0x999a7ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x999a8000 – 0x999afff7 com.apple.agl 3.0.12 (AGL-3.0.12) <53FFD667-5E3E-4140-6A4B-0D283269DC6D> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x999da000 – 0x999deff7 libGIF.dylib ??? (???) <447BC6E8-4C56-3D5D-983B-6BEA0D26F319> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x999df000 – 0x99a22ff7 libGLU.dylib ??? (???) <2C7B2727-26F6-F29D-9D15-33044E87359F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x99a45000 – 0x99a45ff7 com.apple.quartzframework 1.5 (1.5) <4EE8095D-5E47-1EB6-3A8A-6ECE3BEC8647> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x99a46000 – 0x99a53fe7 libbz2.1.0.dylib 1.0.5 (compatibility 1.0.0) /usr/lib/libbz2.1.0.dylib
    0x99acd000 – 0x99ad0ff7 libCoreVMClient.dylib ??? (???) <12EF6056-7AC7-6691-75A2-BD0675C56A35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0xffff0000 – 0xffff1fff libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
    Model: Macmini4,1, BootROM MM41.0042.B00, 2 processors, Intel Core 2 Duo, 2.4 GHz, 4 GB, SMC 1.65f2
    Graphics: NVIDIA GeForce 320M, NVIDIA GeForce 320M, PCI, 256 MB
    Memory Module: global_name
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x93), Broadcom BCM43xx 1.0 (5.10.131.36.9)
    Bluetooth: Version 2.4.0f1, 2 service, 19 devices, 1 incoming serial ports
    Network Service: Ethernet, Ethernet, en0
    Serial ATA Device: TOSHIBA MK3255GSXF, 298.09 GB
    Serial ATA Device: HL-DT-STDVDRW GA32N
    USB Device: USB to Serial-ATA bridge, 0x059b (Iomega Corporation), 0x0577, 0x26400000
    USB Device: 2.4G Wireless Optical Mouse, 0x1d57, 0x0008, 0x04100000
    USB Device: USB HD, 0x13fe (Phison Electronics Corp.), 0x1f00, 0x24400000
    USB Device: BRCM2070 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06600000
    USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8218, 0x06630000
    USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x06500000
    Zak Peric replied 15 years ago 2 Members · 3 Replies
  • Zak Peric
    September 4, 2011 at 7:25 am
    Hi there,
    See if this helps. https://support.apple.com/kb/HT1885
    If it does not than reinstall motion as it says in the article. I had a simar problem instaling motion 5 on same disk. I had to use this and reinstall my fcs studio. https://www.digitalrebellion.com/fcsremover/
  • Matt Frame
    September 4, 2011 at 9:08 am
    Wow, that was easy. I simply did a software update (as directed on the apple site you sent me to) and ‘whammo!’ everything works again. What a relief. Thanks so much for you time Zak. I appreciate it.
  • Zak Peric
    September 4, 2011 at 10:04 am
    I am glad it worked.-)
