Activity › Forums › Apple Motion › Motion 4 forgot how to make H.264
  • Motion 4 forgot how to make H.264
    Posted by Otto Mores on April 10, 2016 at 11:24 pm
    Oddness:
    Suddenly Motion 4 can’t export H.264.
    When I create or edit a preset for H.264, all the correct settings show in the edit settings panels. It all looks fine. But when I close the edit window, DVCPRO is the export format described under the new Preset name.
    If I make a new setting for a codec already listed, it seems to work.
    I thought it worked a few weeks ago. Since then, I’ve had to restore my system disk. Maybe something got deleted. If only I knew where to look and for what.
    Any clues?
    Otto
    Otto Mores replied 10 years, 5 months ago 3 Members · 6 Replies
  • Bret Williams
    April 11, 2016 at 12:25 pm
    Probably something just broke with an OSX update. It is a 7 year old app after all. I’m sure you have a great reason, but I’m curious- why are you using motion 4 and why exporting to h264 instead of ProRes? Seems that even if you needed h264 that you’d first create a ProRes master and use compressor to create the h264.
    The only reason I can think of for using Motion 4 is that you need FCP7 roundtripping capability, but you’re not doing that. Or you’re still using FCP7 and Motion 4 but if you don’t need the roundtripping capability I’d start using Motion 5 if your hardware supports it.
  • Otto Mores
    April 11, 2016 at 4:10 pm
    Thanks for your reply, Bret.
    Good questions. The most obvious being why Motion 4. The answer is that it requires OSX 10. My fairly new MacBook Pro had a problem upgrading, which forced me to restore the older system.
    The other reason is that I rarely use Motion. It was just appropriate for a small job. And now that I started the project in Motion, I need to finish it.
    Of course you are right about writing to a pro format but I’m sending many small updates to a client and it’s more convenient to send tiny files until the final output is rendered.
    Mostly, I can’t upgrade the system until I get this project off and I became curious.
    I’ve looked all over the place and I can’t see the problem. Doing a Spotlight search for H.264 returns nothing useful. A search for DVCPRO, however, returns scads of component looking doodads. Either I don’t know what I’m looking for or it’s not there.
    I can work around it. Just thought somebody else might have bumped into this and knew what would cause Motion, QuickTime, Compressor or whatever to forget how to write only H.264.
  • Robin S. kurz
    April 12, 2016 at 8:17 am
    I’d say that you’re getting hit by the same bug, no?
    https://forums.creativecow.net/thread/170/875263#875263
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Otto Mores
    April 12, 2016 at 9:00 pm
    An odd coincidence. Looks exactly like the same problem only I was trying to use a different codec.
    Thanks for the hint. It does seem that Motion has become confused and may be assigning a codec that is off by one menu choice. Only I can’t get it to render H.264 no matter what I choose.
    And now I see that it is confused about frame rates, too. A few of the built-in Apple render options work. I just can’t change the settings any more.
    If anybody has a fix, please chime in.
    Except upgrading. I’m in the middle of a project so that isn’t much help. 😉
  • Robin S. kurz
    April 13, 2016 at 6:06 am
    Ever tried simply sending it to Compressor??
    – RK
  • Otto Mores
    April 13, 2016 at 6:38 am
    Oh, sure. I can work around it.
    Just trying to figure out what the heck is going on. As I wrote earlier, my Mac is exhibiting some odd behavior and that may be part of the problem.
    Today I was suspicious of some kind of permissions issue or different user accounts that might be confusing Motion but I never figured it out. Probably a dead end.
    Hey, thanks for your interest.
