Activity › Forums › Apple Final Cut Pro Legacy › Motion 4 – after applying “Match Move” , manual keyframing in XY & Z is not stable
  • Motion 4 – after applying “Match Move” , manual keyframing in XY & Z is not stable
    Posted by Philip Hendel on June 6, 2018 at 1:15 pm
    Hi
    I am new to Motion 4 but it seems to be very powerful and pretty straight forward.
    I think I am having a beginner’s problem using “Match Move” and keyframes for XY & Scale (Z) to place a “mask” over some rubbish in a forest
    What I have is a clip with a 2 second section of camera shake + a small zoom in the middle. The camera also pans as it follows an animal
    the Behavior “Analyze Motion” can generate 2 tracks, which seem to be good, but because of the pan I have to use an “offset” in each one.
    The problem I am having is that when I “keyframe” for X,Y,& Z where small corrections are needed, I find that adjustments I make at one end of the clip are also affecting the other end.
    This is happening particularly with “positioning” of the Y-axis, but also happens with “scale”.
    For now I have abandoned trying to include the “scale & rotation” feature in “Match Move” and am only using “position”. Besides XY adjustments with keyframes here and there I would like to also do manual scaling
    This has become a vicious circle, correcting the XY “position” in the first half of the clip also moves previously made “keyframed” corrections in the second part.
    I suspect I am missing a simple step
    Any suggestions would be appreciated as this is beginning to feel like being trapped in a time-loop or perhaps in a Catch-22,
    Philip
    (The site of the small zoom seems to be the point in the clip around which changes on one end begin to translate to the other half of the clip)
    (( I also wondered if the “offset”s may be part of the problem as both track1 & track2 have rather long ones but they are not in the same areas)
    Philip Hendel replied 8 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
