Activity Forums Adobe After Effects Motion 3
  • Posted by Mirela Bogdan on September 16, 2008 at 11:09 am
    I’m looking to add some special effects to video footage and was wondering if Motion 3 is the way to go. The kind of effects I had in mind are things like making inanimate objects move, add in things to the frame that weren’t there before etc… I have been using Final Cut Express and have an iMac. Also, is Motion compatible with FC Express or should I consider other options.
    thanks
    Mirela
    Jeff Asher replied 18 years ago 3 Members · 4 Replies
  • Stephen Smith
    September 16, 2008 at 12:44 pm
    [ mirela bogdan] The kind of effects I had in mind are things like making inanimate objects move, add in things to the frame that weren’t there before etc…
    It depends on the inanimate object, Motion 3 is not a 3D program where you generate 3D people and stuff. Motion has great Motion tracking and masking tools that make it so you can add things that weren’t there before. Hope this helps.
    Salt Lake Video
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
  • Mirela Bogdan
    September 18, 2008 at 7:18 am
    Thanks Stephen, yes this helps a little. Does Motion 3 allow you to move these added people or objects or do they remain still?
  • Stephen Smith
    September 18, 2008 at 2:54 pm
    Yes, you can add objects or people and move them. And I think it does a great job. I created this Motion tutorial on Creating Customized Motion Templates and the open shows a bunch of objects that I interact with. Hope this helps.
    Salt Lake Video
  • Jeff Asher
    September 19, 2008 at 7:33 pm
    You may want to look into After Effects. It sounds like you’d get a lot of use out of the Puppet Tool: https://www.keyframer.com/index.php/2007/06/after-effects-cs3-puppet-tool/
    Also, if you want Motion 3 you have to buy the whole Final Cut Studio. That isn’t a bad investment but make sure you know exactly what you are getting into.
    Finally how old is your iMac? Motion 3 is very unkind to older video cards so be sure to compare your card to the minimum system requirements for Motion 3.
    You can do the things you ask in both After Effects and Motion but for those specific needs you may find After Effects the best bet, although a bit harder to learn initially.
    Be sure to Google comparisons between the programs as well to find other differences.
