Activity Forums Apple Motion Motion 2 crashing
  • Motion 2 crashing
    Posted by Bill Parker on September 14, 2006 at 8:24 pm
    I’ve been using Motion 2 in HD720p and am experiencing multiple crashes. I mostly use the application for photos. I trashed the perferences and crossgraded to FCP Studio 5.1 to no avail. Can anyone suggest something else to fix the problem?
    I use a G5 w/ 4GB of RAM.
    Thanks.
    Lance Drake replied 19 years, 11 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    September 30, 2006 at 11:58 am
    It’s really stable here… so I’d suggest a clean install of a new startup disk… Sounds a bit like the “sledge hammer” approach, but I really believe this should be done periodically… at least every time a new OS is installed… not updates, but upgrades you pay for…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Lance Drake
    October 2, 2006 at 8:41 pm
    Motion has taken the (unfortunate) step of performing lots of their magic in the MacOSX KERNEL memory-space under the auspices of a kernel process.
    When something bad happens – like a memory resource error – not only does Motion crash – but it takes down the whole system.
    Whereas, when an app and it’s resources are all located in USER space – then when something bad happens, there’s hope to recover – or, failing that, the app can crash – but NOT the whole system which is what happens with Motion.
    This approach they’ve taken is really a sad situation and, unless they get out of KERNEL space and not do all their work in a kernel-process, this kind of nonsense is going to keep being a part of the Motion experience.
    FWIW – The times I most often run into trouble are when I have something going on that uses almost all of the system RAM – and that’s not hard to do – or when I am rapidly clicking around from viewing-area to viewing-area and it seems to get behind and lost in the updates.
    HTH
