Activity Forums Apple Motion motin 5 default
  • motin 5 default
    Posted by Jim on July 12, 2011 at 12:56 pm
    I’ve downloaded Motion 5 to start to check it out on a secondary system. It has become the default version of Motion and if I want to open a previous version project and keep it in Motion 4, I have to manually open Motion 4. Is there a way of making Motion 4 once again the default version?
    BTW, I want to especially thank everyone for their responses and insights regarding this unfortunate X situation. I will ultimately need to make some hard decisions in the next few months, and the cumulative wisdom found here will help to make an informed decision.
    Jim
    Carsten Orlt replied 15 years, 2 months ago 3 Members · 2 Replies
  • David Stembridge
    July 12, 2011 at 5:31 pm
    I’m with you there… I went ahead and zipped it for now. Look forward to figurin out if I want to go that route, with new x versions and all as well.
  • Carsten Orlt
    July 15, 2011 at 1:09 am
    select a motion project in finder > get info > change the ‘open with’ menu to Motion 4 > select change all
    from now on double clicking a motion project opens vers4. Also open in editor from FCP7 opens Motion4
