Activity › Forums › DaVinci Resolve › MotherBoards
  • MotherBoards
    Posted by Simon Blackledge on November 24, 2012 at 8:50 am
    So the Asus is in the spec but is there anything out there that will allow the below ? Or do I just get the Supermicro chassis now rather than an interim PC ?
    1×690
    1×600
    1x decklink
    1x R680
    would like to put a 1x 10Gig Nic in also.
    ta
    s
    Al Arnold replied 13 years, 9 months ago 4 Members · 4 Replies
  • Peter Chamberlain
    November 25, 2012 at 6:23 am
    HI, your board combination is unusual but either way, following the config guide Supermicro system will offer the best performance as it has four independent x16 slots.
    Peter
  • Alex B carr
    November 25, 2012 at 7:29 am
    I’ve got the Asus Z9PE 2011 socket Dual Xeon. Currently just one GPU GTX 680, but 10GE, HD/SDi, and x2 ATTO cards.
    I’d say Davinci works pretty well in Windows 7 and Mac Mountain Lion. The GTX 680 was overheating so I switched to a water cooling setup. Temp dropped from 75C+ down to 35C.
  • Simon Blackledge
    November 26, 2012 at 9:30 am
    Hi Peter,
    Why do you save it’s unusual ?
    1x ui card
    1x gpu card
    1x sdi i/o
    1x raid hba
    Surely most people would require these in a system to run Resolve?
    Or did you mean something else?
    Simon
  • Al Arnold
    December 8, 2012 at 5:58 am
    Currently running this board w/ multiple GPUs, & blackmagic decklink.
    Resolve working perfectly:
    https://www.newegg.com/Product/Product.aspx?Item=N82E16813131798&Tpk=asus%20p9x79%20ws
    If you’d like dual CPUs:
    https://www.newegg.com/Product/Product.aspx?Item=N82E16813131817&Tpk=asus%20dual
    I have no experience with this board though.
