Activity › Forums › Maxon Cinema 4D › motext material slipping off faces!
  • motext material slipping off faces!
    Posted by Christa Jarrold on November 9, 2024 at 3:24 pm
    I wondered if someone might be able to help me with this c4d problem that I can’t find a fix for online anywhere..
    My motext material is ‘slipping’ off the faces of the letters. I’ve set the projection to cubic, which is the only one that fits as I can’t UV unwrap motext. I’ve even tried the ‘pin material’ tag but that doesn’t work either. Any help appreciated, I’m using the latest version of C4D and have attached an mp4 of the output below- and you can see the texture won’t stick to the faces.
    Any help is massively appreciated! Happy to send the project file if that helps.
    Thankyou!
    Kouraib Abdmalek replied 1 year, 10 months ago 2 Members · 1 Reply
  • Kouraib Abdmalek
    November 10, 2024 at 12:34 pm
    Hi, Christa,
    The solution to the problem may be to make the MoText editable and then control the extruded Spline as needed, either by making it editable as well to get polygons, and then you can use Connect or Cloner as your needs and the purpose you want to achieve. You may have forgotten to attach the video or it did not appear for some reason. I hope you will upload it again, and publishing the file will also be helpful in understanding the situation.
