Activity › Forums › Avid Media Composer › Most portable Avid editing solution?
Posted by Tim Young on February 4, 2011 at 3:05 pmHi, If I want to tweak my sequences at home or on the train, what is the most compact/portable solution for running Avid MC5? Could I use a Macbook Air?
Richard Cardonna replied 15 years, 7 months ago 5 Members · 5 Replies -
Michael Kammes
February 4, 2011 at 3:18 pmUnfortunately, no.
https://www.avid.com/US/products/Media-Composer-Software/system-requirements
Use a qualified Windows Laptop or MacBook Pro. Also, make sure you have at least 4GB of RAM if you plan to make a new purchase of MC and a laptop.
~Michael
.: michael kammes mpse
.: senior applications editor . post workflow consultant
.: audio specialist . act fcp . acsr
.: michaelkammes.comHear me pontificate: Speaking Schedule .
Jeff Greenberg
February 5, 2011 at 4:12 pmAir? No way. MBP? Sure. just check what the qualified hardware is.
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com -
Job Ter burg
February 5, 2011 at 5:22 pmI wouldn’t write off the Air.
I’ve occasionally worked on a 2.16GHz MacBook (non-pro), and that seemed to work. Trouble with the Air may be connecting a drive.
Also, you might like to have some screen real estate.I’ve got an MBP 17″ with MC5 and PT9, and an MXO2 mini. It’s the greatest thing, but still a bit heavy to carry around. It’s more for setting up a working area outside of the studio (most importantly as a portable setup in the back of a mixing theatre).
Michael Kammes
February 5, 2011 at 6:40 pmI would suggest waiting a few weeks. THEN look into a machine that will run Avid…say, after Feb 15th.
~Michael
Richard Cardonna
February 6, 2011 at 7:02 pmIf you are open to pc I am running avid mc5 on a vaio vpc-f1390x with no problem. this vaio has great features specs I7 quad turbo, 8gb ddr3 ram, nvidia 435, 1 gb ram, 1080 display, w7 pro, 7200 hdd, its got express card slot, esata, firewire and usb 3. all for less tha 1,800. 6.4llb
Richard
