Activity Forums Adobe After Effects Most likely cause of ghost lines?
  • Most likely cause of ghost lines?
    Posted by Jerry Smith on July 14, 2016 at 4:08 pm
    I create a pixel perfect rectangle in PS. Put it in AE. 99 times out of 100, everthing is perfect. But 1 time out of 100, there might be a ghost line on one side as though the rectangle’s position of anchor point was off by some fraction of a pixel. But all the properties end in .0000
    Bizarrely, when I try to reproduce the problem, I am successful! In other words, some rectangles in some projects seem to insist on having ghost lines.
    Also, is there an easy solution? I thought Matte Choker would provide an easy fix, but I was unable to dial one in.
    Thoughts?
    Jason Jantzen replied 10 years, 1 month ago 3 Members · 2 Replies
