Activity Forums Adobe After Effects Expressions Most efficient way of injecting line breaks
  • Most efficient way of injecting line breaks
    Posted by Edward Clayton on September 23, 2022 at 1:25 pm
    As part of a larger expression, I need to inject line breaks after each character in a string. I have something that works (hacked together from another post here), but was wondering if there is a more efficient method, since I’ll need to be doing this to multiple strings at once.
    idx = 0;
    outStr = "";
    while (idx < value.length){
    if (idx > 0) outStr += "\r";
    outStr += value.substr(idx,1);
    idx += 1;
    outStr
    Edward Clayton replied 3 years, 11 months ago 2 Members · 5 Replies
  • Dan Ebberts
    September 23, 2022 at 2:20 pm
    Like this maybe:
    value.replace(/.{1}/g, '$&\r')
  • Edward Clayton
    September 23, 2022 at 2:24 pm
    Brilliant! Thank you, Dan 🙏
  • Edward Clayton
    September 23, 2022 at 2:50 pm
    How could I replace the hard-coded line break with a variable?
    v = "\r";
    And is there a good reference/directory for this type of syntax (i.e. “‘$&\r'”)?
  • Dan Ebberts
    September 23, 2022 at 4:45 pm
    Like this:
    v = "\r";
    value.replace(/.{1}/g, '$&' + v)
    Any good JavaScript + Regular Expression reference should do.
  • Edward Clayton
    September 23, 2022 at 4:56 pm
    I thought I tried that, but I must have had a typo somewhere…works perfect! Thanks again.
